Schroder LT x Kuzma 4 point x Graham Elite x SME V-12
Which of these tonearms is the best?
  • Total voters
    53
bonzo75
22,619
13,637
2,710
London
There is a big difference between the reference and the LT due to no string bearing on the latter. Also Steve says latter has much better bass
cyclopse
51
3
8
How many other tonearms have an adjustable bearing? This is by adjusting the magnet gap as you probably know.
bonzo75
22,619
13,637
2,710
London
Ok didn't know that.
At Munich last year on the same table they had the Schroeder CB with an Allaerts boron mk2 and the LT with a Lyra (etna, iirc). I preferred the Allaerts. That said I don't trust hifi show set ups, but was good to know the cart drove the decision
infinitely baffled
1,259
387
340
Scotland
The one I am selling has wood arm, silver wiring with RCA. It can be changed to metal arm by Steve.
Can i ask, did you sell your arm?
Puroplatino
18
4
70
48
BruceD,
Thank you for sharing your views. It is nice to see several people voting for the Kuzma 4 Point. At the same time, so far I have not heard anything negative said about the Schroder LT, so currently these two seem to be top choices.
Regarding listening for myself, that was easier when I lived in NYC and could have equipment demoed in my system, but now living in Brazil, in practice it is impossible to compare these tonearms in my system. Also, I am now buying my first Vinyl rig in over twenty years, just bought the turntable and phono preamp, and will soon buy the tonearm and cartridge.
I will try to go to CES and some audio dealers and listen to these tonearms, but with different turntables and cartridges (and speakers, amps, preamp, cables, etc) it would be rather difficult to fairly compare tonearms. Consequently I have to gather the opinions from fellow audiophiles and just buy one.
Cheers,
VPN
The only potential drawback of the LT is they prefer a stable platform. If you have something like a Minus K that Döhmann uses it can be a problem. That’s why in the Helix One Döhmann uses a different Schröder and not the LT as it is very sensible to any minimal vibration or rack movement. If this isn’t a problem I say go with the LT. If on the other hand you have a rack which absorbs vibrations by allowing movement of the rack then go for the Kuzma 4 point.
Reactions: bonzo75
bonzo75
22,619
13,637
2,710
London
thanks. do you have any friends with the LT, what carts are they using
jfrech
2,156
751
1,160
Austin
I agree with your points. I'll add that I've since moved from my 4-point to the Safir-9, it's a MUCH better arm in all areas. At this point, it's, by far, the favorite arm I've owned vs the SME IV.Vi, Tri-Planar, LT, Centroid and the previous 4-point.
Reactions: Puroplatino
jfrech
2,156
751
1,160
Austin
I used a Lyra Atlas, I have a friend that had a Lyra Etna and Olympus. I know the Lyras are a good match...
bonzo75
22,619
13,637
2,710
London
i have heard it on the Lyra atlas through the Rockport Lyra and CH stack. The Olympos is a very musical Lyra.
IIrc your LT had an issue with not having a stable platform?
jfrech
2,156
751
1,160
Austin
Correct, I use Grand Prix Audio Silverstone F1 racks which have some sway to them, plus was on a 2nd floor so some flex in the floor joists.
