Hi guys,
I know this is a "best of" forum. I thought there would be a thread for asking about issues. Didn't see it.
Any how here goes..if you're going to remove my post so be it...
About 2 months ago I bought a cheap fridge from Best Buy. A $550 Insignia 18-cbft size. One of the smallest. Every day there would be a faint POP sound from the side. Right side. This happened years ago when I bought a 18 cu Samsung...that time the pop sounds sounded more like some one was bouncing small rocks INSIDE the fridge from time to time. Don't recall if the sound went away. Or if I called for a repair man.
Any ideas what's going on with my new fridge? I assumed you just plug in a fridge. That there's nothing to be setup first?? Something in the back? Odd this happened with another fridge i bought 8 years ago. I had moved since.
Thanks.
Thanks.
