Just curious, but how do you define 'active' and 'passive'? In my mind both the Cyclops and Triton are passive since they contain no circuitry that requires power. My understanding of the Typhon is that it is just more of the Triton, or more of the Cyclops.
Hey guys, i think it will be helpful if I go through a brief description of each product.
VENOM DEFENDER
- provides 20,000 amps of surge protection
- contains an MPDA which reduces noise on the power line
- operates in parallel to the AC circuit
- created to provide surge and noise reduction for the VENOM PS8
- can also be used in the bottom outlet of a duplex to provide surge and noise reduction for whatever is plugged into the top outlet, usually something like a sonos or TV, etc
- a low cost solution instead of power conditioners
HYDRA CYCLOPS
- originally designed for high current amps
- provides Triton level performance
- contains NIC chambers similar to Talos
- contains an MPDA (so a DEFENDER is unnecessary)
- has only 2 outlets and no circuit breaker for best DTCD
- think of it as a hot rodded Triton if you don't need the 8 outlets
HYDRA TYPHON
- orginally designed for exclusive use with the TRITON for reference level oerformance
- it operates totally in parallel to AC circuit and carries no current load
- some enterprising folks decide to use it in the second outlet of a duplex for their amp
(similar to way you use a DEFENDER)
- can be used to improve performance of any HYDRA
- however it is an expensive unit
- it really needs one of our top umbilical cables to deliver its best (python or anaconda)
