I am the happy owner of a Coherence II preamp.
A few qustions:
As the cord to connect battery power supply with preamp has deteriorated (outer isolation falling off in pieces), I ought to replace it.
Would it be safe to use the old cord with a new outer shrink wrap?
I am afraid the cable‘s inside isn‘ t much better.
Are there alternative cords, maybe better sounding ones?
Battery swapping: any tricks to get old batteries out?
One always gets stuck inside and wouldn’t move …
Other batteries than those Panasonics originally used you can recommend?
Should I give these here a try?
Thx in advance for your input and any other info for Coherence II information!
A few qustions:
