SoulSonic Hologramm-X
16,017
13,347
2,665
An new speaker design by the talented and very nice Miro Krajnc:
A tall, thin ribbon with four 15" woofers and one 12" midrange per side. The dipole speaker is 240 cm (almost 8') tall.
spiritofmusic
14,606
5,415
1,278
E. England
Ron
You've heard Apogees, I know
Just why would you want dynamic woofers w ribbons as here?
The Graz Duettas I heard were so complete, of a whole, and apparently fully extended measured down to 21Hz w such solidity and texture, just why would you want to create any discontinuity w drivers?
16,017
13,347
2,665
I simply am reporting on a new speaker development.
Measured down to 21 Hz with what drop-off? I have trouble believing they are flat down to 21 Hz.
I had Martin-Logan Monoliths and Monolith IIIs for many years. I don't think I am particularly sensitive to the crossover discontinuity if it is implemented carefully.
To answer your question regardless of full-range driver design I like large cones brought in low, around 25 to 30 Hz. I would add REL No. 25s or JL Audio Gothams or 18" Velodynes or Seaton subwoofers or Wilson Thors, etc., to Apogees, Analysis Audios, Magnepans, Martin-Logans, Wilson XLFs, Rockport Altair IIs, etc.
(The surface area of the cones in the Pendragon equates to about 2 1/2 15" drivers per side.)
thekong
246
135
948
I agree, I don't believe even Graz’s Duetta Sig. can reach anywhere close to 21Hz, if we are talking about -3db.
The stock Duetta Sig. had a quoted spec. of 30Hz (-3db), and the Fullrange was 25Hz.
I had the Fullrange and Duetta Sig. placed at the exact same location of my room, driven by the same exact electronics. Some of the low bass information I heard from the Fullrange was not even hinted at by the Duetta Sig. I was so amazed at what a difference that last 5Hz made!
