I may well have found a 16" vintage idler, and RCA70a, 120V 60Hz which will have me sort the power issue as one of the first step after cleaning the motor and bearings and re-lubing them. Now I am looking for good sources to read up on the various ways to use that beast in a 230V 50Hz environment
Given the recent data on use of solar power for audio elsewhere on this Forum it seems that a 120V 60Hz inverter may be an (fairly easy) option?
(simply convert 230V into whatever goes into the inverter probably 40 or so Volts DC and feed that to the inverter)
Other than that I'm sure there is loads of chores to do to revamp it, as it likely originates back to the '30-ies. Happy read up at whatever links you can post!
