Spectral DMA 30 SL: Volume Change Sound
Console
32
5
138
Timbuktu ;)
Spectral DMC 30 SL: Volume Change Sound
Hi there,
I have bought an used 30 SL G1 in new like condition and love the sound. I habe two questions / observations though:
1. Is the low "motor sound" of the volume control normal, when switching the unit on or changing the volume?
2. On Volume Level 1 (1x LED on) there seems to be a slightly improper Balance between left and right channel. Can the balance calibration be off or change due to age? From LED 2 upwards all is perfect.
Thanks for sharing your experiences!
#1 If you can hear the motor from afar, then I would say this is not normal; from up close, yes, the motor can be heard
#2 You may be splitting hairs here, as I can't see anyone listening at -90dB; or did I miss something? You may want to contact the factory about this if it bothers you.
I hear the motor from my listening position, when I change volume without music playing. It is a low sirring sound. 2.5m away from preamp.
Frankly, so can I when the room is quiet (late at night), but it's extremely subtle and I have very acute hearing still
Interesting observation: I am using a programmable universal Logitech Remote. The inbalance between the channels just happens with the Logitech! Using the Spectral Remote, all is superb! Wow, strange and interesting. So the original remote is on the table! :)
Interesting indeed - no real idea why this would be, but a guess would be that the pulse durations are not the same.
Yes, the original Remote seems to "lock" at certain ranges. The Logitech seems to sit "inbetween" in the lowest volume setting. It 100% reproducable! But the preamp is 100% balanced with the original remote. So... machine is running perfectly. Very happy! The oddity of inbalance was somehow disturbing, though it was just in that 1 setting with the Logitech remote. Very sensitive machine, the DMC 30 SL... :)
I checked for reference with another 30 SL. The sound of the volume control motor is the same. I don't find it subtle though, Ack. But knowing this is normal, gives me comfort.
Well, subtle against the volume we play music at :D
