Totally respect Alrainbow's experience and observation. Mine however is different.
I have used solid-core 10-gauge copper wire encapsulated in a flexible steel jacket to excellent effect in very high-resolution systems. This is especially true with longer runs and when multiple dedicated lines are run in parallel to one another. Some say that enclosing cable inside steel conduit or flexible steel jacketing kills dynamics or creates other problems. I have experienced no such effect, only a dramatic reduction in the noisefloor.
Here is a photo of one system where the flexible steel-jacketed solid-core power cable was used and the results were excellent when directly compared against the former unshielded for cable runs. The cable as referenced was run 25 feet under the floor from an in-wall Equitech panel in the utility room to (5) dedicated lines terminated at the outlets behind the equipment.
Not a generally stocked item (most supply houses stock flexible aluminum jacket cable for use in commercial installations) but definitely available without too much effort or wait.
In case anyone is wondering acoustically optimized shades do drop down when it's time for serious listening.
