Is it a loss if it has not been sold ? Mentally it works for me, im simpleIs "not officially" a loss the same as an unrealized loss?
It certainly helps to have a huge house with many suitable rooms to indulge in that "collector style" enjoying different systems of different kindsas long as you never sell your old equipment you have not officially suffered a los financially ! Micro, Tang and i have mastered this strategy, it only requires sufficient storage space
Glad to hear it worked for you - as indeed it should. I guess what I had on my mind last night is I'm still looking at source equipment from the perspective of a loudspeaker designer (hobbyist and/or semi-professional at one time) - it's supposed to get out of the way, not supposed to get compensated for in the loudspeaker design. The same goes for the other major factor in the overall sound of a system: the room.To second acousticsguru’s post about the impact of room acoustics and treatments, about a year ago I (with considerable help from my local dealer) treated my listening room with a combination of absorption and diffusion panels. The room had a fairly nasty ‘slap echo’ which made even the best components sound harsh in the upper midrange and lower treble. I had lived with it for a long time, and finally decided to do something about it. The effect was pretty dramatic. I hadn’t realized just how bad the room was until it was fixed. Although the total cost of the treatment was only about 5% of the total system cost, it probably produced the biggest positive contribution to the systems overall sound. The midrange in particular went from having a harsh sound at certain frequencies to being rich and detailed. I realize now that You can’t really make a judgement about how a piece of equipment really sounds unless you hear it in a decent room.
Wow, that sounds awesomeI'm having an acoustic ceiling (not to mention new floor and - Yikes! - windows) built into what I'm hoping is going to be my future listening room.
I'm concerned with the relevance of some of the critical statements here and elsewhere. I do believe a SOTA DAC is worth owning, that's not the point. Even so, if someone had asked me a year ago, I'd have said that loudspeakers and room acoustics are ten times as important. That's being coy: they're contribution to the overall sonic result may well be a hundred times as important (or more). Can't be overestimated is more to the point.
Earlier this year, I got to hear a dCS Vivaldi stack in a room that had an all-glass front on one side, concrete on the other, and when the owner said something to the extent that he couldn't hear an appreciable difference between his Vivaldi stack and a Chord Dave, I was quick-minded enough to reply: "I believe you." What I really meant to say was, I would not have been able to tell a difference in an acoustically untreated listening room like that either.
Either your room was REALLY bad or your system at that time lacking serious resolution. I haven't had a system, well ever, that could easily hear the difference between amps, DACs, preamps and even cables. Even my relatively low resolution Dynaudio system from 20 years ago could easily tell preamps, DACs and yes even power amps.That mirrors my experiences. Before I started out with acoustic treatment in 2012, I could not hear a difference in my system between a then almost 20 year old Wadia 12 DAC and a Berkeley Alpha DAC. After the first set of treatments, the difference between the DACs was huge, starting with resolution of fine detail of timbre.
Some rooms may have a very good base quality by themselves, but set-up of the system, including speaker positioning, will still matter greatly. Since he is fortunate to have a room with unusually favorable acoustics, a friend could take out all his audiophile room treatments. Yet that does not mean his room isn't fine-tuned acoustically. As a an example, he has removed all glass from the picture frames -- and it matters.
You're kidding, right? Heard of the pandemic? Works have been postponed repeatedly all year long. Meant to have parts of the house painted, meant to have Ethernet cabling swapped, meant to have fibre installed, never happened. I'll send a pic of that one room via WhatsApp, tomorrow or the day after, when the floor is dry… Speaking of which: it's snowing outside, not even plaster is drying, worker leaving fan heaters on, so it'll shrink and needs to be redone etc., super-cool for the environment, we're partly looking forward to the end result, partly fuming…Wow, that sounds awesome
Is there a time frame for this already?
But that is exactly what goes through my mind. Paul McGowan once said that when one walks by an open window and hears a piano play or voice sing, we instinctively know whether there's a human being practicing or a system playing back. Same is true for the difference between we perceive as inherent to the recording and the playback system. You only need to listen to your favorite music in your car. You could tell if it's the recording. What about if the song were on the radio and completely unknown to you?A real performance in a bad room is still easily identified as a real performance...never forget this easy lesson! It might make the performance less pleasant to listen to but it doesn't undermine the realness of the sound of that performance. You might say, "Oh that sounds poor" but you won't say, "Oh that sounds like a bad recording or reproduction".
I have furthermore found that speakers that were widely regarded as average or even poor can sound extremely good with a really good source and and amps. It is interesting to hear how much elevation in performance of speaker is possible when you give it proper support. I would much rather have, if I had to choose, a system built around mid-level speakers and reference level electronics than I would a reference speaker with mid level electronics...the former is more likely to have a far more realistic presentation.
I once bought a system for a non-audiophile female colleague. At first she wanted a home theater system but first we went shopping for speakers. We bought a nice pair of Audioplan Kontrast 3s that fit within the budget. She came back to me saying that she and her husband now wanted a good 2 channel stereo system and we had to find a cd player and amp. The amp they had (an old Denon integrated) made the poor speakers sound broken. Numerous others eventually lead to them buying the Cary Audio CAD572se monos and a modified Transcendent Sound GG preamp from me and a cd player from Primare (I wanted to find something better but the budget prevented it). It was no contest really compared to other items in the price range... The room was nothing special, no treatment, just some furniture but the difference in sound was between never listening to music for pleasure to budding audiophiles...just from amp changes. It totally changed how they looked at sound reproduction. This was a lesson to me in how electronic artifacts destroy the sense of realism in reproduced sound. Room treatment won't fix that problem. The other lesson it taught me was that the devil really is in the details as to what inhibits realism in reproduction and the big fixes will help in some ways but they don't attack the underlying issue of unnaturalness.
Hi Al. Yes my room is decent, but I would love to have the bigger dimensions of your room. As long as I could keep the fireplace and have complete freedom with regards to room treatments and speaker and listening seat positioning, I would love to see what my gear could sound like in a bigger room like yours.
Based on my own experience in my room with my treatments, I now happen to think that audiophile room treatments, well mine and in my room context, can easily cause more problems than they solve, mostly by over dampening the sound and filtering out information. And I have heard great sound in completely untreated rooms.
It's an interesting topic, but perhaps better left to its own dedicated thread. I don't even know what I am doing on a "SOTA Digital" thread. LOL.
True. The problem is that room treatment may differ depending on the dispersion pattern of a speaker (e.g. open baffle needs diffusion IF the distance to the rear wall is greater than 2.5x the lowest wave length of the diffuser, and/or absorption if not, etc. & etc.). Unfortunately, there is no speaker type whose dispersion pattern will solve all problems by itself. And even if there were, any such concept would directly translate into a room size (including golden ratio proportions) that I've yet to see in this country. I've visited audiophiles in countries where real estate and cost of labour permits building audiophile "barns", but I also know some Japanese who shower at the gym because they're storing their wine in the bathroom, and have to sit on the bed to listen to their system (as, incidentally, I have to these days), so…The effect of the room will also depend on the speaker type, however. It appears that because of their radiation patterns electrostats are less sensitive to quality of room acoustics than conventional cone speakers. It seems to be a consensus that similar holds true for horn speakers.
Going back to the thread subject, the DCS Vivaldi is a great source of music, but also an excellent tool to evaluate subjectively the room treatments - the other DACs I have used are much less ambitious.
The effect of the room will also depend on the speaker type, however. It appears that because of their radiation patterns electrostats are less sensitive to quality of room acoustics than conventional cone speakers. (...)
The idea that electrostatics are less sensitive to quality of room acoustics than conventional cone speakers comes from the old Quad ESL63 that had a narrow figure of 8 radiation pattern, as they were a point like dipole. IMHO this isn't true of most electrostatic speakers. In fact I found that most electrostatics, due to cancellation modes, are very dependent of listening room acoustics - they can sound miserable is non supportive rooms.
My room does have some advantages in terms of dimensions, yes. However, it also has one essential disadvantage, which is width (12 feet). Your room, Peter, is considerably wider. I am almost certain that your larger speakers would give some boundary problems in my room due to interaction with the side walls, if not very well set up. These problems might be minor, but they could also be major. The speakers might still sound good right away, but probably not good enough according to the high standards we are used to from our systems. The problems might be fixable in the long run (perhaps with room treatments, oh horror), but it's unlikely plug-n-play.
You are over-generalizing, Peter.
Actually, it is a topic very appropriate for this thread.
In a less than optimal room, a SOTA digital rig might look nice and shiny in its rack -- pretty, for sure.
But it will NOT deliver the sonics of SOTA digital playback.
In theory a dipole speaker in a room without boundaries cancels its bass due to phase cancellation.The room interaction is a key point to get a decent bass response from a full range electrostatic. This implies proper distance to front and back wall, as well as proper absorption/reflection properties of the wall - when we address phase cancellation, wall reflection means less and spiky bass. I found that ESL 63 electrostatics can sound lean and analytical is some rooms.Fransisco, what do you mean by a "non supportive room"? And what are the sonic consequences with electrostatic speakers in such a room?
