streamer or DAC ?
germinal
77
47
23
41
Can someone tell me what would give the best sound quality ?
Let's say budget is 10K
a basic streamer with a very good DAC ?
or a very good streamer with a basic DAC ?
or a third option.. a decent all in one device..
Also : what does sound best ?
Spotify with top notch DAC
or TIDAL with so and so DAC
Maybe this is a bit too general but I thought I might give it a shot ;)
bryans
920
876
250
Hmm you could go with something like a Meitner MA3 (DAC/Streamer). What are you using for a music management solution?
Reactions: Audire
Gregadd
1,787
1,850
Metro DC
It is possible too use your wifi as a streamer.
Tidal is fantastic
christoph
4,674
4,071
825
Principality of Liechtenstein
DeadWax
187
162
115
57
All things equal (rarely are they), I'd overweight the DAC quality over the streamer. I prefer to separate these components to allow for more flexibility down the road so all in one units don't interest me for the most part. And +1 on Qobuz.
Gregm
530
383
155
France
I second DeadWax above re, favouring DAC over streamer and Qobuz over Tidal.
Gregadd
1,787
1,850
Metro DC
I agree on the dac.
Gobuz over Tidal? Could you please elaborate?
Do you think the price is better?
Is it the size and variety of the catalog?
Is it the sampling rates and sound quality?
Personally I found Gobuz wanting on their on merit, let alone when compared to Tidal.
iMO of course.
Edit:I will take advantage thier free trial.
germinal
77
47
23
41
At the moment an auralic Altair G1..
was thinking about a lampizator DAC (seems they do something special compared to the other DAC's and get good reviews as well) and maybe a Lumin mini as streamer.. or maybe just an older MacBook via USB ? Something wrong with that option ?
Reactions: christoph
christoph
4,674
4,071
825
A Lampi DAC is always a good idea :cool:
Reactions: DeadWax and Gregadd
MRJAZZ
408
208
350
Check out the HI FI ROSE 150, Network Streamer/Dac. It’s a huge “bang for the buck” at 5 K MSRP.
CHEERS......
Reactions: AZWink and germinal
GuutEnuff
2
41
Have you considered the Matrix Audio X-Sabre 3. Well regarded streamer and DAC with roon, spotify, and tidal options. Just got one myself and am very pleased with it. Only $3k though, so way less than your budget, but punches above its weight.
germinal
77
47
23
41
After testing several dacs ranging from
3k to 10k I have to say I can’t hear a difference between the DACs.. also streaming from a MacBook over usb and streaming from
Decent streamer.. can t hear any difference…
strange
bryans
920
876
250
strange
My advice is if you can't' hear any difference get a 3K DAC with MacBook and save yourself some money. Use the money for something else in your system. There is nothing wrong with a 3K DAC if you are happy.
Reactions: germinal
TDX
338
281
150
Both change sound, could be significant. Dac last longer though so maybe buy a very good dac first.
Gregm
530
383
155
France
I agree on the dac.
iMO of course.
Yes, it is the sound quality. Otherwise, as you imply, the Qobuz catalogue is not as complete. I listen to classical and Qobuz has a reasonable selection of hi-res offerings, including recent recordings.
Gregm
530
383
155
France
I second that suggestion, 3k dacs can be very satisfying.
Case in point: I downgraded* from a MSB Select to a 2.5k Ayazi and I am still alive ;) and enjoying the music, no psychological stress whatsoever.
Fron end is a tweaked MiniX fanless unit -- not even a server (couldn't afford one :))!
*Financial setback
Reactions: germinal and MRJAZZ
Armsan
217
229
275
strange
OK, that’s fine but, if latter you’ll want to address that problem it will be a fun challenge. There must be a bottleneck somewhere, obscuring the transparency and the resolution of your system. The room?! The quality of the power and/or the power cables?!
In that price range, the DAC differences are significant.
Reactions: dsnyder0cnn
germinal
77
47
23
41
Thanks for the suggestion... I have this one running at the moment... it seems you can't change anything (settings) on this streamer/DAC.. is that right ?
justubes
211
102
273
Please do not forget or neglect everything that comes before the streamer. A whole ecosystem before.
Start with a dac you like and start with a reference the sound with cd be it Tidal or Quobuz. Find also which service you find more material you like as opposed to the sonics.
That should be you base point which wood then steer you and dictates the choice of streamer chosen and not to forget, budgetting over time for the network "infrastructure" which is the real source material which you have control over.
The networking complexity requires effort and importantly time to finally find and setup the best of what you have and make to best of it.
bryans
920
876
250
Sorry when I had my Meitner I was using it with Roon and controlled everything from Roon. I know you can use mConnect with the Meitner. Maybe you can change setting via this app.
