Studer A80 preview machine need rollers
Ingenia
13
I have recovered this machine from an old studio for vinyl cutting.
It can be seen that some rollers are missing for the ribbon travel
I can not find a data sheet for this block of heads. Does someone have it available?
what diameter are these rollers? same diameter of tension rollers?
yjwu
78
12
913
Taipei, Taiwan, Republic of China
I do not have A80. I just make up the story by looking up the threading chart.
It looks like you can still do 7.5" - 45, 7.5" - 33.3; 15" - 45. You need one more roller to do 15" - 33.3; additional two more rollers to do 30" - 45 and 30" - 33.3. 15" -45 should be the default configuration previous owner used.
Since your machine can do 15/30, it would be possible to move one roller at the top of the triangle to upper top position. This way you can do both 15" - 33.3 and 15" - 45; and of course 7.5" - 45, which is not supported by your machine. Nothing else.
Overall you need two more rollers to unleash the full potential of this A80. All rollers of this preview-delay should be of the same size.
Actually you only need one more roller to do the following:
7.5" - 45 (not available on your machine)
15" - 45, 15" - 33.3
30" - 45
Congratulations!
4,700
You were lucky - I remember reading that with some very simple optimization of the tape path (I think it involves removing some parts) these vinyl cutting machines can be converted in a top reproducer. All you need is a very knowledgeable person to guide you.
