Has anyone been lucky enough to compare the two? Is there a significant difference if at all???
Will you contribute to a go fund me page to help me purchase Shane?Just buy one Joe and tell us if any difference. The new burl wood swirl is pretty.
I saw them in person in Munich 2019; the European representative told me the crossover changed as pointed out above and that the front baffle was made more stiff as well as the new finish option being added but that's all I remember. He went on to say in a somewhat indirect way that sonically the Mk2 and Mk3 (the Tx) were close sonically.All I could find
New Reference Speaker TAD R1-TX
Technical Audio Devices Laboratories, Inc. (TAD) is proud to introduce a new generation of Reference Series Speaker Systems, called R1TX. Following the concept of using highest expertise available…www.audiophil-online.com
Has pricing been discussed. I own the CR-1 MK2 version before the TX and saw the price almost doubled..... There must be a significant improvement one would think?I saw them in person in Munich 2019; the European representative told me the crossover changed as pointed out above and that the front baffle was made more stiff as well as the new finish option being added but that's all I remember. He went on to say in a somewhat indirect way that sonically the Mk2 and Mk3 (the Tx) were close sonically.
before selling any loudspeaker you should try to get good sound from it. I am sure if you can not get good sound from TAD then you will not get good sound from any other loudspeaker.TAD R1 tx-eb loudspeakers
TAD R1 tx in emerald black.Present as new, approximately 30 hours of use.Change in direction see me selling them at around $100,000 below the RRP.https://soundline.co.nz/collections/tad/products/tad-reference-one-tx-floorstanding-speakerswww.aussieaudiomart.com
Selling my new TAD R1 tx and going down the Rockport trail. Price in AUD.
