Telefunken G73-R
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
1,613
1,484
553
Has anybody here used these? Am interested in how they compare to the top nos 12au7 suspects eg tfk802s / amperex 7316 / amp & tungsram e80cc.
Also does anyone have a pair to sell?
Sablon Audio
May 22, 2015
1,613
1,484
553
Here’s some blurb I found
Surpassing the quality control requirements of the famous Telefunken ECC802S, these are extremely rare, limited production, black shield coated, avionics/aircraft grade, factory selected Telefunken G73R. Manufactured solely for Agilent Technology and Hewlett-Packard, the proprietary G73R part number and RFI/EMI black coat shielding indicate the highest quality grading on the planet. This illustrates exhaustive aftermarket testing for low noise, uniform output, low microphonics, freedom from physical defects, long heater life and an even, uniform cathode emission.
The finest West German manufactured Telefunken tubes, with smooth plates and diamond marked, these have G73R hand written on the outside black shield coating. Records indicate they were only available as spare parts for Agilent or H-P equipment. Critical use in hospital and aerospace equipment demanded tubes with extremely low noise and tightly controlled output. The ultimate tube for Hi-Fi, tube mics and mic preamps, these tubes are very fine, highly rare and in great demand. Authentic, the real deal, the bottom of the glass is diamond marked. Matched pairs and quads are available with tightly controlled transconductance from section to section and from tube to tube. Astonishingly accurate, the sound image blooms out of a dead quiet background.
DasguteOhr
2,406
2,574
645
Germany
Congratulations, extremely rare good tube, so looks uncoated.
the best tubes of all time were made in Ulm.
matakana
373
188
115
61
UK
The Business then , be interesting in your findings, what are they going to be used with .
Sablon Audio
May 22, 2015
1,613
1,484
553
@DasguteOhr thanks Stephan!
@matakana - I’ll keep that one close to my chest for now but will post my findings later next month. I will also be having some regular tfk802s / amperex 7316 / fivre / cv4003 / raytheon 7730 to compare.
Reactions: Scott Naylor
DasguteOhr
2,406
2,574
645
Germany
My pleasure, when you find the 6211 /e 82cc gold pin version buy them,sounds so sweet amazing good bass and midrange.
Sablon Audio
May 22, 2015
1,613
1,484
553
Those aren’t qualities typically attributed to TFK; are they possibly produced by ano and relabelled? Siemens & Halske maybe? I also have amperex miniwatt e80cc which should cover the sweet space plus Siemens labelled Tungsram e80cc for the more analytical presentation.
DasguteOhr
2,406
2,574
645
Germany
what did not meet the quality requirements of telefunken was relabeled as AEG, Lorenz. Yes, there was commissioned work that was then done by Siemens, RFT and Valvo. This tube came from the Ulm, code on the back and was produced for foreign markets, hence the 6211designation.
DasguteOhr
2,406
2,574
645
Germany
Be careful don't go over 250volt anode voltage and 6mA current, then they works fine. not a good replacement for every circuit.
