I bet this Romanian DAC called the Wavequest sounds better.
Yes! And the Thrax should be called the "Mafia DAC" Check out Nigel Farage saying the Bulgarians are Mafioso:Considering it's from Romania, they should have called it the Vampire DAC....
This type of DAC relies heavily on the accuracy of the resistor.
Apparently MSB thinks much more of their Diamond resistors than the lower level ones. I think most folks think the diamond sounds better too. Maybe there are other reasons the Diamond sounds better, but according to MSB, the boards are very important. Maybe that's just marketing. I haven't heard any of these DACs. If I were going to audition one of these I would pick the Wavequest 2 when it comes out because the output can easily drive an amp and I believe the volume is dithered by a 63 bit FPGA. Sounds like my kind of DAC. Not that I'm looking for another ladder DAC, though.For the measurements, yes definitely. However where SQ is concerned it seems that resistor accuracy isn't the most important aspect - otherwise why would TDA1543 (where resistor matching is pretty appalling) still sound quite decent?
My experience of DACs tells me that a DAC's dynamic performance is more important for SQ than its INL and DNL which are traditional static measurements for DACs related to their resistor matching.
http://www.youtube.com/watch?feature=player_embedded&v=V72mZCDwmY0
