Many audiophiles believe that when wiring up one’s system it is best to use the same model and brand of speaker cables and interconnects and power cables throughout the system. These folks believe that the sonic goodness in that model and brand of cable is maximized by having all of the wires the same.
Other audiophiles believe that whatever error or coloration is exhibited by a particular model and brand of cable is magnified if you use the same model and brand of cable throughout the system. These folks believe that there is no way that one model and brand of cable can be the best-sounding connector between all possible pairs of components.
What do you do? Do you use one model and brand throughout your entire system, or do you mix and match cables? Why?
Have you ever compared both methodologies in your own system?
