Tonearm upgrade Project JukeBox E
Akyskylz
2
53
Can you upgrade the tonearm on the Project Jukebox E? For example to the Project Carbon tonearm?
Akyskylz
2
53
Thanks for the info on the 8.6 inch size. What about this? Would this work?
Project 8.6cc Debut Carbon Tonearm Replacement​
The Replacement Pro-Ject 8.6 CC Tonearm (1944 191 410) has been designed to fit the Debut Carbon, Debut Carbon Esprit SB and PS01-Wave Pro-Ject turntables. Manufactured from Carbon, the 8.6CC is quite a special tonearm being incredibly rigid yet lightweight gives it has the quality it need to ensure your vinyl records sound simply staggering.
docvale
542
53
940
Briarcliff Manor, NY
Measurement wise, yes.
You should check how easy the process of removing the old arm would be.
Curiosity: why would you change arm with another from the same maker and the limitations of the same length?
I'm asking since I'm in a similar situation (8.6" Pro-Ject arm, on an RPM 1.3) and I came to the resolution that I'm going to either invest on a new, better cartridge or I'll change the entire vinyl rig with something that is born on a higher level (e.g., Rega P8).
daytona600
722
151
955
scotland
Ortofon 5E cartridge have you tried a better stylus 10/20
Jukebox intended as a all in one modern music centre
