Top of the Line Tube Amplifier Companies?
Colt12
6
3
3
I am familiar with the top of the top (cost wise) solid state amplifiers and am wondering about the top of the top tube amplifiers?
I am well aware that cost does not equal best and best sound is subjective. I am curious about which companies use the most over the top and advanced manufacturing techniques to make their tube amps as premium and “luxury” a product as possible.
VAC and Kondo come to mind. Maybe Conrad Johnson ($40k reference amp) and Jadis as well. Einstein audio, too? I am thinking of counterparts to Goldmund, CH Precision, FM Acoustics and the like. Do any more besides the ones mentioned exist? Mostly just curious. Which tube manufacturers utilize the most expensive and sophisticated manufacturing processes?
I recently watched a factory tour of CH Precision on YouTube and was wowed by the excessive lengths they go.
ACHiPo
519
309
310
Pleasanton, CA
I'd definitely include AtmaSphere in any list of top-quality tube amps. I've also heard great things about CAT. Of course there are a lot of highly regarding flea-watt SET amps for the right system/speaker. Audio Research, BAT?
Bachtoven
1,002
399
340
I would add Ayon Auido to the list.
LL21
14,423
2,516
1,448
My favorite tube amps (that I have heard) are:
1. Zanden Ref Monos. Their special edition references: Seikoh, Chukoh, etc are apparently stupendous. Amadeus here has their Preamp.
2. CJ...but have not heard their latest 30 reference amps
3. VTL Siegfried II Monos
4. Shindo (but its a very personal approach to sound)
Other amps I am intrigued most by:
3. Lamm
4. Atmasphere
5. Kondo
6. Aries Cerat
Reactions: Argonaut
4,700
(...) I am well aware that cost does not equal best and best sound is subjective. I am curious about which companies use the most over the top and advanced manufacturing techniques to make their tube amps as premium and “luxury” a product as possible. (...)
IMHO you will find that most companies making what many find to be the best sounding tube amplifiers are artisanal manufacturers - and no one will give you details on the development techniques, just a few general comments with marketing objectives.
I think that at best you will get a list of our members favorite tube amplifiers, irrespective of manufacturing technology. The more technological tube amplifier I have owned and own is surely the VTL Siegfried II - all static parameters are controlled by microprocessors, includes several advanced microprocessor diagnostic and protection systems and even two time counters - non resetable manufacture and resetable tube play time!
mtemur
1,406
1,346
245
48
- Kondo
- Komuro
- Lamm
- Shindo
- Audio Tekne
- Tenor (Old)
- Air Tight
(Not in any particular order)
Reactions: No Regrets
joaovieira
391
273
970
Brazil
I’d add Audiopax.
audiopax.com
Salectric
381
500
998
Custom amps made by Aldo d’Urso in Italy using Western Electric transformers and other vintage parts.
Emotive Audio Vita
GuillaumeB
268
88
333
UK
www.boyeraudio.com
I don’t know if this is helpful at all:
In addition here is a basic circuit description of the ERIC Encore which came from Lars himself and which I think I am ok to share:
“At the input there is a switch to select between RCA, XLR and DIR. RCA and XLR go through a input transformer. DIR is bypassing the input transformer. After the transformer there is a gain stage which is a long tail differential amplifier with EC8010 triodes. The gain stage is capacitor coupled to the driver stage. We use tin foil and Teflon capacitors. The driver stage is two 6L6GC in balanced configuration. The driver stage is transformer coupled to the PA stage. The PA stage is 845 power tubes and output transformer. There are two separate power supplies. One is 1000V for the PA stage. This is made up of two mains transformers in series, a bridge rectifier with four 6CJ3 tubes and a filter with two chokes and three 1500V polypropylene capacitors. The other power supply is 400V for the driver stage. This has its own mains transformer, GZ34 rectifier and a filter with choke and a polypropylene capacitor. The power supply for the gain stage is made of a non-feedback regulator from the 400V. The gains stage has choke filtered DC filament supply.”
Cheers,
Guillaume
Reactions: matakana
