Tube amps with TAD CR-1's ? Recommendations ?
joeinid
Active Member
Mar 15, 2011
1,537
1
38
NY
#1
Is any one using tube amps with their TAD speakers? I am actually thinking about trying Conrad Johnson ART amps, either the ARTsa stereo or ART monos. I have to believe that combo will be wonderful. Thoughts?
LL21
10,671
38
48
#2
Go for it! Bet either are great...with TADs which can take and use the extra power...monos possibly even better??
LL21
10,671
38
48
#6
Duke LeJeune
Jul 22, 2013
149
5
18
Princeton, Texas
#7
I probably wouldn't recommend a tube amp for the TAD CR-1. Its impedance curve averages about 8 ohms north of 400 Hz, and about 4 ohms south of 400 Hz. Most tube amps will sound a little weak south of 400 Hz on that speaker. Yeah I know that's probably counter-intuitive, but that's my take based on looking at the impedance curve and frequency response curve and taking into account that it's a stand-mount speaker.
That being said, low stands and/or placement near the wall would help out down there, so maybe with a little extra boundary reinforcement tube amps would work well. In that case, I'd probably lean towards push-pull tube amps over specialty tube amps (SET or OTL), at least from a frequency response standpoint.
MylesBAstor
#8
Aug 11, 2012
56
#11
You should listen with Doshi Audio setup ... great combination.
joeinid
Active Member
Mar 15, 2011
1,537
1
38
NY
#12
I’m sure the Doshi are wonderful. I tried just about everything (and I mean everything) on my CR-1 but had to move on after about 2 years. Everything was great in its own way, but I could not shake the forwardness of the treble of my TADs. It was just too in my face for me and seemed a couple of dB more pronounced than everything else. It was almost painful to me with some volume. But they were terrific late night or low volume level listening speakers.
Likes: bonzo75
LL21
10,671
38
48
#13
Hey Joe, Happy New Year. Been a while...I have lost track of your system. What is it these days? I looked up your profile where the system part says "see signature". Would be great to hear how your system has evolved!
Dec 7, 2014
101
#14
View attachment 46545 I have the TAD ME1 and find they sound much better with solid state than with tubes. Much more dynamic and alive and I am fan of tubes.
I'm driving my TAD E1 with ARC REF250SE. In the summer, I was using Hegel H30. Once I found a good matching PC on the Hegel, it was more different than one is much better than the other. If I had to choose, I did choose .... sold Hegel, I prefer ARC with superior timbre and more organic.
I'm back in the market for a SS amp again to use in summer. At this moment Agostino and Soulution are tops on the list.
Mar 15, 2011
1,537
1
38
NY
#15
Hi Lloyd,
Yes it’s been a while. I have Avantgarde Duo XD now and a variety of amps. I’m ecstatic with these speakers. Absolutely wonderful.
LL21
10,671
38
48
#16
Congrats...which amps work well with those amps?
LL21
10,671
38
48
#18
Very nice! Have heard good things about First Watt.
