All IME/IMO. Bear in mind I do not have any tube gear in my current systems but have run many tube circuits over the years including several of my own design.
Tube designs tend to be single-ended with relatively low feedback. That makes them more sensitive to matched devices than typical SS circuits. Matching of both sides within a dual tube as well as tube-to-tube can be important to provide the same gain and frequency response from each channel. Matching power tubes in a push-pull design can also reduce distortion.
The tolerable difference depends upon the circuit and how sensitive you are to mismatch in gain (mainly, again IME/IMO). I usually strove for 1% matching but that was not always possible.
With new tubes, I checked matching after a few minutes to check for gross problems, then usually again after they had been running a few hours, and again around the 50~100 hour mark. That meant basically when I plugged them and and they had warmed up, at the end of a day or two of listening, and again after about a month. After that it depends but roughly every six months if using them daily. That said once the tubes had stabilized (which IME happened after 10~100 hours) they would often run for a 1000+ hours (power tubes) to 10,000+ hours (low-level tubes) before nearing EOL. At that point they would start to vary significantly but other things would indicate they were going bad as well (lower gain, higher noise, etc.) My experience is outdated at this point, but 1-5 years for a pair of power tubes and 5-10 years for a preamp/low-level tubes was not out of line, depending upon the design. Some designs run the tubes hotter than normal so they fail more quickly; others run them under-biased and they will last longer. I tended to use DC filament bias and there were claims that shortened their life; I did not observe that but my sample size was small. Running higher B+ voltage and greater current would drastically reduce their life (as some audiophiles and quite a few CB radio fans discovered).
FWIWFM - Don
What is the value of tube matching?
What is the tolerable difference of tubes being matched vs. unmatched?
How frequently do you match? weekly monthly? yearly? only when you first get them?
