USB Cable recommendation
Tim F
125
43
113
I have a USB re-clocker and need a cable to go from my streamer to it. I have no idea if I need good quality given the fact that the device "should" improve the signal after it leaves it. Looking for a USB cable recommendation for £200 or less. I'm in the UK so ideally not something I'd have to import from the USA as the fees tend to be high!
What do you guys recommend?
Cheers, Tim
VoicesInMyHead
158
308
170
Sweden
Your system is no better than it's weakest link etc etc.... I would try to get a somewhat decent USB cable after all. My current personal favourite USB cable is the Sablon Audio 2020 model, although maybe a bit too expensive in your case, and then my second favourite and perhaps more price worthy at half the price and closer to your budget would be the Phasure Lush^2. Both of these have outclassed some much more expensive cables in my system. With the Lush^2 I wouldn't get a too short cable as it's quite stiff. I can sell you my Lush^2 (shipping from Sweden) if interested, send me a PM.
Reactions: Sablon Audio
