Wadia WT 2000 transport
nirodha
407
30
433
Hi all,
are there any users of the Wadia WT 2000 transport out there? Is it still a valid choice?
Cheers,
Wim
thedudeabides
1,509
179
485
Alto, NM
Wadia no longer makes players or transports.
Best to not buy due to potential future servicing issues.
Al M.
6,042
1,443
453
Greater Boston
That is correct. I had to retire my Wadia 8 transport after 20 years due to the lack of spare parts at the factory when it needed repair. The 2000 transport is even older.
Al M.
6,042
1,443
453
Greater Boston
By the way, technology has progressed. I found an equally good sounding replacement for my Wadia 8 in the Simaudio DT 260 tranport for just 1800 bucks. And I don't plan to replace the transport once I will upgrade after some time to the Berkeley Reference DAC. I think the DAC itself and an upgrade to even better power conditioning (Shunyata Triton, perhaps even Triton/Typhon) will make a greater difference than a more fancy CD transport. The power conditioning issue is absolutely crucial for digital, and I plan to provide the Reference DAC with the best power input it can get.
still-one
1,541
67
490
Milford, Michigan
That is also the reason I moved on from my 971 Series 9 transport. It was beautifully built but I was concerned with ongoing support.
