Hi Lloyd,
This was an interesting and entertaining discussion of different low frequency solutions that I missed the start of, but recently noticed this set of questions was left unaddressed.
I know this was directed at Duke's line of answers, but I'll add a few thoughts of my own. A few more recent setup/calibrations I've worked on have allowed some unique configurations and range of adjustments, giving a little insight on ways to deliver the lowest frequencies in our listening rooms. I purposely make reference to multiple methods as the is no single ideal answer for all systems and rooms.
Question 1 comparing equidistant main speakers and sub towers vs more flexible placement options has many dependent variations where the specific qualities of the listening space and placement of speakers and subs within the room are going to play a role in how the different options work out. The side wall with phase shift suggestion is an interesting concept, but quickly becomes intertwined with the even delivery of the low frequencies to the listener. This recommendation from David Griesinger was in response to a subjective perception of "bass in the head," which became of interest well before we had such ready availability of measurement equipment. I've never seen this problem demonstrated in a system without strong modal resonances due to room and sub/speaker placement, and still question if it's chasing a red herring.
There are are most certainly interactions between multiple low frequency sources, the room, and the resulting magnitude and time behavior at the listener which affect the perception of low frequency origin and cohesion with the sound of the speakers. We do have to remember that many 2 channel system ideals, goals of purity, or component selection automatically limit what flexibility we have in adjustment.
The location of the subwoofers have impacts beyond just the direct time-of-flight, as at the lowest frequencies, it's a fuzzy separation of direct energy vs the overall interaction with the room. Significant changes in the frequency response do affect the time domain, and our hearing is quite sensitive to changes in the decay of the bass/subwoofer spectrum, so there's no case of physical alignment where it makes sense to ignore the magnitude (frequency) response. There are some coincidences we often see with certain approaches that happen to also work out from a modal/response perspective. Looking at what works from such configurations and what might be missing from a measurement standpoint can give pointers in where to experiment and test next.
Question 2: There is difference to a larger area, more distributed bass source vs a more condensed point. In terms of a reasonable size box/cube vs a tower, so long as the tower isn't just a single, elevated point, it usually offers some advantage with respect to room interaction. So far as actual production of bass energy, it's very easy to underestimate the dynamic distortions in a real loudspeaker, especially as each voice coil starts getting more than 10-100W in more than the shortest of bursts. Remember that in terms of surface area, 12 vs 2 woofers is equivalent to using 6x larger diameter voice coils in the 2 woofers, and the required excursion from the cone reduces by 6x for the same SPL. That means the level that would require more than 6mm of one-way travel just shifted more than 15dB higher.
Put another way, the sound output which required a peak of +/-6mm of cone movement from the pair, well within the intended limits of most any modern, subwoofer driver, now only requires +/-1mm of motion, and each voice coil sees
*1/36th* the amount of power when we move to 12 woofers. That is quite a significant difference in operating conditions for both the woofers and the amplifier driving them. It's impressive if a driver designer is able to double the power handling or linearity of a given woofer design without significant compromise elsewhere. This is a multiplier of capability with the primary compromises being total box size and cost.
2B: For wide dispersion designs, midrange and HF diameters will be necessarily limited due to maximum width and spacing from the adjacent bandwidth drivers. If you look at displacement capabilities in the 50-150Hz and 100-500Hz range, you will see much more variation. Of course I use the metric of displacement not surface area, as there are many cases where woofer choice can make for 2-4x the displacement capability from the same size cone. Generally with larger Sd at lower frequencies, the higher possible system sensitivity, up to the limits set by the mid and tweeter. This choice of woofer cone area and overall sensitivity also dramatically affect the required enclosure size.
This makes a strong case for separate woofer columns, as keeping the upper frequencies on smaller dimension boxes (even if tall) makes resonance free construction easier, while woofer columns then can be larger and not as concerned about resonances above a few hundred Hz. The dilemma is of course that a monolithic speaker eliminates another variable in setup, narrowing the possible options to try in a room, and leaves less rope for the owner.
Thank you! This is fantastic. So now 3 basic questions which are bolded/underscored for ease:
1. What in your mind is the high level difference between the approach that Gryphon, Evolution Acoustics (MM7 Model), and musicfirst100 are talking about...which is super-large sub towers in 'equidistant arc' facing the listener...and your suggestion of subs along the left and right center walls facing "the listener's ears". (Or for that matter...the Genesis 1.2 or YG Acoustics Sonja XV or Wilson XVX/WAMM + Subsonics...where the sub towers are generally behind towards the outside of the main speakers?)
Is the arc method or 2 sub towers behind essentially creating a bigger/badder version of 2 speakers facing you...while the L/R center wall method is creating more 'surround sound'?
2. Regarding your warning of 'too much bass'...i totally get that. On the other hand...
2A. Is there a difference between playing 2 x 12" woofers loudly and 12 x 12" stacked woofers more softly (both placed in the same location) other than distortion? Somehow, I think the answer is a big yes...but if yes, I do not understand why. I have to imagine movement of air itself must have something to do with it, relative to 'realism'.
2B. Somehow, i look at the number of speakers out there in the 'reference' set and note that while some have greater 'scale' than others, most of them do NOT vary much in treble and mid cone square inches...it is in the bass. Therefore, I wonder whether there is a LONG way to go before one has created 'too much bass'...
- Most reference speakers seem to deliver around 60-120 square inches of treble and mid cone surface area...rarely much more or less than that.
- But the woofer square inches can vary massively from 180-200 square inches on smaller 'reference speakers which still have 1-2 x 1" tweeter and 2 x 6"-7" midranges...(Magico Q7, Rockport Lyra, etc)...to upwards of 400 and even 700-1000 square inches with sub towers (Evolution Acoustics, Wilson, YG, Gryphon, Genesis, Stenheim)...and then of course the REL dual-stack of 3 x 15" subs for each sub stack...
As a base starting point, do you find it appropriate for audiophiles to look for massive custom-designed/installed bass enhancement for reference speakers (ie, upwards of 500-1000 square inches of cone surface area...dual Thors, massive SWARM, REL dual-stack)?
