There are too many variables, including humans in the loop, to come up with any definitive rules.
You may think you can spot general trends that appear to be true to you. So you may formulate rules.inside yoir head. But as your experience improves, you will find exceptions and prove to yourself that the very rules you formulated are flawed.
To decide that various valve types sound best is flawed. It simply isn't true. There are poor to excellent sounding versions of most valve types.
The same applies to Ked's assertion about valve power output and sound quality.
This is hi-fi. It is the nature of it. It will constantly mess with your perceptions and mind. Over time you will see your view of What's Best change.
You may even go round in circles. Like Ked, who is back into MLs in a big way, or so it seems
Just needed to make this point after what I have read so far in this thread.
Over 40 odd years I have used valve power amps far more than solid state ones. Whatever the speaker I have had at the time. Just sayin'.
