Wilson Sophia 11 questions
Mike
963
158
953
Madison, New Jersey
I currently have my Wilson speakers sitting on a hardwood floor, but without spikes or wheels. The floor is not very flat, so I felt that spikes wouldn't make sense. Is it better to have them on the wheels? Will they mark the floor?
Sorry for the dumb questions.
Sunny
Adding spikes and brass Disks on moving Pads allows you to really Voice the speakers. Once you're satisfied, remove the pads and kick back with your favorite music. You will be blown away.
Pierre
45
Denmark
I also have an old not flat woodn floor.
My Sasha are on spikes with Herbies disk underneath and this sound just wundefull....
I know many uses Stillpoints under Wilson, but i dont like the "sound" from stillpoints. For about 2 years ago, i had a suitcase from Stillpoints at demo. All the differents stillpoints, so i could try them all. Not my cup of the ;)
Mike
963
158
953
Madison, New Jersey
Thanks, everyone. I wonder if I can put the speakers on the spikes. Maybe I need another person for help, as the speakers are quite heavy..
Sunny
That's great. Getting Fundamentals correct is awesome.
I understand. Stillpoints and other products are based on personal likes and dislikes. Trial and error.
Kingsrule
1,441
704
1,430
I wish Wilson would tap a hole in the front center of all their speakers to give the option of using 3 spikes, 1 in the front and 2 in the rear.....
Why
Do you feel that's a better configuration.
Lildebs888
361
5
Grantsville, Utah
www.facebook.com
I would think that having 1 in the front and 2 in the back would make the speaker less stable, and possibly be knocked over
Sunny
That would be a horrible horrible Idea. The weight of the speaker would make it unstable. If my Dog's tail hit it, I would be in trouble or if a small kid leaned on it, It would fall and injure someone.
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
Or 3 at the back 2 in front , mike the finite elements are great on wooden floors and are fully adjustable per feet , the 70 mm wide base makes hardly an imprint on soft wood , regarding flipping over , just keep the front feet wide enough apart, the finite elements are also a " shaft- hole design " with a large base so the feet themself are verydifficult to tip over as compared to common spikedesigns
DSC_0103 by andromeda61, on Flickr
Lildebs888
361
5
Grantsville, Utah
www.facebook.com
+1
Lildebs888
361
5
Grantsville, Utah
www.facebook.com
Off topic: Do I spy a Studer? Reminds me of my dad's "Ultramaster" :) (at 2:02 - https://www.youtube.com/watch?v=479ybdkWeFs&list=UUI7oe8H-P1lUFD7GfXrkaxQ )
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
Yes thats right its a standard A 80 i have a portable B 62 as well , great machines , i bet your fathers ultramaster sounds even better with a lower noisefloor
Lildebs888
361
5
Grantsville, Utah
www.facebook.com
They are wonderful! :)
Kingsrule
1,441
704
1,430
Not really. The weight would keep it stable. Of course anything can be knocked over
And I didn't day change to three spike design, just give it as an option...
With 3 spikes:
Easier to get each woofer cabinet the same height
Easier to level.
Sonically a much more desirable result
With 3 spikes:
Easier to level.
Not sure that I agree with respect to level the speaker. I can tell you that my speaker had 4 spikes and it was level in all planes. I have subsequently switched to four Sillpoint Ultra 5's under each speaker and I can tell you mine are perfectly level. As for sonic change I do agree as I have learned this from number and placement of Stillpoints used.
thedudeabides
2,170
675
1,200
Alto, NM
No need to level with three spikes. Of course you can adjust and should have all three at same height on initial setup.
YG uses three on all their models. It is most assuredly a more stable setup.
Had one of their speakers in my room for a few days. No stability issues assuming speaker has some weight.
Of course, if you have the drunk uncle or kids (unsupervised) visiting, caveat emptor.
