Your preferred playback method
How are you playing the sound from Blu-Ray discs?
  • Total voters
    12
RBFC
46
1,225
Albuquerque, NM
www.fightingconcepts.com
How are you all playing back the audio from your Blu-Ray discs?
1. HDMI with decoding in the processor/receiver
2. HDMI with decoding to PCM in the player
3. Analog output from the player
Lee
RUR
3
SoCal
Same player, same approach. If I were to replace the gear today, I'd probably get an Oppo and decode in the AVR.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
I don't have a BDP that accepts Analogue inputs but that is what I would use. I used analogue for SACD with my former Oppo player and preferred it.
John
Ron
31
I'm using the analog outputs from the Denon DVD3800BDCI.
Lee
I have the Denon Blu Ray 3800bdci also. I use to use the analog outs to my Primare SP31.7. That was the only way possible. Now with the McIntosh MX150, I use the hdmi cable, so the processor does the decoding.
Mark (Basspig) Weiss
682
37
940
New Milford, CT
www.basspig.com
Using analog outs on my players. My audio gear is mostly 2-channel. My C LS & RS go direct to the loudspeaker manager for those channels/amps. Eventually, I'd like to route them to my mixing desk, and then I can set up any 6 or 8 channel mix and route it to any speakers in the theater. Presently, only my two Oppo players can feed all the channels.
flez007
2,915
36
435
Mexico City
My HT setup is still 2CH, I have a 100inch screen with a Runco 1080p projector feeded from my Oppo BR player that also serves me as CD transport.
naturephoto1
820
7
16
Breinigsville, PA
www.nelridge.com
For my system with my Oppo 83SE NuForce Edition I play bitrate from the player to the Onkyo Pre/Pro 885 Processor through HDMI. However for 2 channel listening I run the output via Coax to my Lavry DA10 DAC (I also have a CD transport for Redbook CD going to the DAC) which goes to my ARC LS10 Linestage Preamp. Additionally, for multichannel SACD and DVD-A I run 6 analog cables out from the Oppo/Nuforce unit to the Onkyo Pre/Pro.
Rich
DWR
262
10
Western burbs of Detroit
I use the analog outputs from my Oppo 83SE to a Rotel 1068 prepro which does not have HDMI capability, for multi channel. For 2 channel the 83SE has the Modwright tube modification running through Audioquest cables to my Conrad Johnson PV-14L preamp.
