Phono stage recommendations
DWR
262
11
Western burbs of Detroit
Ok fellas can some of you give your suggestions/opinions on phono preamps, I am hoping that you can break it down to say $1000 and under,$2000 and under, and over $2000. Thanks in advance.
Under $2000: for older, get one of the CAT preamps from the early 90's, great phono sections, or for newer a used Allnic H 1200. Some of the old CAT's can be had for 1k-ish. For real cheap, get a Yamaha C-70 from the 80's, preferably refurbished, for around $200, wonderful phono section.
Over $2000 is a broad territory, out there you need to hear what you buy, preferably in your own system, taste will determine where you go there.
But I don't remember the CAT working real well with even 0.5 mV output MCs. There were issues with noise and inadequate gain resulting in lost dynamics. So careful cartridge matching is essential.
My friend also had an issue with the volume control being too coarse and not being able to set the volume needed.
One inexpensive phono section worth checking out is Lehman audio. Gain is between 61-66 dB for lower output MCs (it's around 40 dB for MM). Some other circa $1000 phono sections that I haven't heard include the Phonomena phono section from Musical Surroundings and designed by Michael Yee (he has done some nice inexpensive phono sections over the years starting with Monster Cable), Sutherland, Whest and Heed audio.
I second the SP-9 though many don't like it. With the right tubes (I have vintage Bugle Boys) this preamp will sing. I also like the PH-3SE. Another inexpensive tube choice, and built like a tank, is the Anthem PRE-1.
I am using a VPI Scoutmaster signature with JMW Memorial 9 arm and a Dynavector Karrat 2D cartridge and a Jolida JD-9A phono pre. I had an Eastern Electric Mini Max phono pre and was not that impressed with it. I have just recently "rebuilt my system from separate 2 ch and H/T to a combination system. The phono pre is one of the pieces I am still looking to upgrade. As for going to another full function preamp no I am not going that route. My CJ PV-14 is going out for major modifications in August and I will be staying with that linestage preamp. I am just trying to get peoples opinions on what is good in the $2000 and under price range. One option is to have the Jolida modified also.
OK I ended up going with a hand built unit from Aural Thrills, they advertise on audiogon, I looked into Tom's work and decided to give one a try, and I sure am glad I did. This unit is a two piece unit consisting of a tube rectified 274B power supply and the preamp itself using 4 12ax7 tubes. The total price including an Emmision Labs 274B and 4 NOS Bugle Boy 12ax7 tubes was right at $2000. I will write a review after using the unit for a month or so, but right out of the box I am very pleased with what I am hearing.
I had a Dynavector Karat 2D before. To fully appreciate the delicacy of its high frequency, you need the Dynavector head amp. Unfortunately, they do not make this head amp anymore. I think it is worth the effort to acquire the head amp if you will keep the Karat.
I'm using a Modwright SWP phono stage which I like a lot. I used a PH3SE from Audio Research for a year and enjoyed that too but I wanted more gain.
I recently got back into audio/LP collecting after a looong hiatus and needed a phono preamp. The Jasmine LP2.0 SE was recommended by a few people whose ears I trust. they run $520 incl post from China I got a used one on A'gon for $400. this thing rocks! 40 and 70 db of gain 47k for MM and 50/100/250/1000k loading for MC. the sound is superb for the money. Big wide stage, layered depth, plenty of air and palpability - it’s so right in my system. at high gain the s/n is excellent, there’s remarkably little hiss and this thing is 100% discrete using matched JFETS. My point of reference are the phono sections in klyne sk5a, CJ PV-9, ARC Sp-14 (ol' skool)
Rob
Wow, I've always wanted to check out one of the Aural Thrills units... I went for the Bottlehead Eros, and coming from the seduction, I must say I am very happy with it.
I'm looking at the Jasmine units as well... my new obsession (reel to reel) has me re-evaluating my system priorities...
The Eros wants SUT's to run Moving Coils, but with an Adcom vdhII HO Mc the sound is superb direct with no stepup.
The new Manley Chinook.
