That maybe a better option. By the way what brand is your Pandora DAC
Aesthetix
Well, time for me to ruin this thread.................
A lot of the AES/EBU cables that we have measured are NOT 110 ohms. Including some very famous names.
They should try their hand at USB cables.
Over and out.
Maybe a stupid question...but can you tell me how one can measure the actual impedance of an AES/EBU cable? I am anxious to actually measure the values of mine....
Have you ever actually tried that method? Somehow, I doubt it, and/or your results.
You are just going to have to trust me on this one. (I doubt you will find anything viable, via Google. We had to bribe someone at SWBT to find out the secret, and why no one could copy it. Hint: 1 kHz capacitance.)
Steve,
Please try to do all of us a favor, and keep the trolls out of this thread. As soon as they show up, I am out of it. If you guys are interested in learning, that is fine. If you want to throw the same mud at us, like you do on every other forum, not going to take it.
Thanks.
Go ahead...............measure a cable at 1 kHz, then try to tell me how it will work as a transmission line. Nope, not buying it.
As for taking the manufacturer's spec'ed capacitance and inductance.................the way they measure it frequently is not the numbers you will get when you use the cable in its intended manner.
Anything other than a TDR measurement is of dubious value.
You can chose to ignore or dispute my stance, but if want to debate, as soon as AT&T "ABAM" cable gets introduced into the fray, the game is over. You are just going to have to trust me on this one. (I doubt you will find anything viable, via Google. We had to bribe someone at SWBT to find out the secret, and why no one could copy it. Hint: 1 kHz capacitance.)
As to manufacturers specifications: If you can't trust the source then don't use their products. As I said, characteristic impedance is easy to calculate if you know the dimensions and dielectric material of the cable. The LCR and characteristic impedance of a cable does not change with application but different measurement techniques and procedures do provide varying results.
TDR measurements are fine for measuring cable reflections and propagation speed but don't provide an accurate measure of characteristic impedance. I have found this article interesting for those that are technically inclined:
http://www.ecadigitallibrary.com/pdf/IWCS05/IWCS0593_ogx.pdf
Pat, I am not disputing your stance because I really don't know what that is other than you are a self-described expert and seem very upset about something. So, if this is a private party carry on with it.
Impedance, I think.Exactly what is the test going to prove or disprove?
Impedance using an LCR meter:
For low frequencies characteristic impedance can be measured by using the so called "open short" method. The open circuit and short circuit impedance is measured on the longest piece of cable that can still be considered a lumped element, usually one tenth of a wavelength. The characteristic impedance is then given by the square root of the product of the two measurements. The drawback of this technique is accuracy. The open circuit and short circuit measurements may be beyond the reasonable accuracy range of the network analyzer. A better method is to measure the open and short circuit impedance using an impedance analyzer that uses a current voltage technique and can therefore measure a wide range of impedance.
