Can someone link me to J J's paper? It's getting referenced a lot here these days and I've lost track of where, in what thread, it was linked.
Tim
Tim
That isn't the case theoretically, is it? How does this occur in practise then assuming that the RIAA playback curve is accurately adhered to?There is less HF energy, less LF energy in vinyl.
I'm not so sure about the compression that is mentioned but yes, the mid & highs is where vinyl sings.There certainly is the things mentioned above about crosstalk and intensity differences that are frequency dependent, and as such, less lows and highs is a sort of compression WHEN compared to what digital is capable of. I hear distortions in the low bass in vinyl, but the interactions of crosstalk and intensity and L/R issues make a more pleasant sounding mid to HF (what limited amount compared to digital there is) sound field. And I am talking playback here, not concerned about what is theoretically possible at the cutter but what is the reality at the consumer.
Are you saying that a small amount of compression that slightly squashes dynamics has the effect of perceptually increasing the dynamics? That's an interesting idea - is there any background support for it?
Yes, that is what I am saying, and have read research on the matter. I don't have a link to provide at the moment. I didn't read it online anyway, but in texts on hearing.
It is a long time since I was in the business (left in 1976) but low level detail was always amplified when cutting the master for LP to keep it away from the surface noise. I don't know about dynamics but I would expect that is why the low level detail is more obvious on LPs, it really is louder relative too the average sound of the rest of the music.
CDs tend to be limited by soft (or often not so soft) limiting the high levels which does not have this benefit.
Ok, I can agree with that. In my system at least,the digital version always has a smaller perimeter or a different perspective,but mostly it seems 'letterboxed" to me versus the analog copy. It seems like the analog version is not limited in this way and whether the original was recorded tube or solid state that doesn't matter. This perimeter is especially noticeable between AAD and DDD copies. It is not psychoacoustic related,it is fundamental betwen the two formats,I think. What would cause this? I don't think it is distortion related at all.
f1eng
I agree with you .
@roger
How can you be absolutely be certain that it is not a matter of mastering? AFAIK there are few if any digital and analog with exact same mastering . I actually would like to be pointed toward such. Additionally and there I know I am threading a sensitive issue.. Under what conditions? I can safely bet knowledge wasn't removed.
I just wanted to pick up on this highlighted phrase as I see it used often as meaning that "it's not a delusion". I find this a confusion of what the term "psychoacoustics" means & leads possibly to some confusion. I believe that psychoacoustics is the study of the perception of hearing more focussed on the signal processing from the auditory nerve onwards. It doesn't mean "delusional". Sorry, I just wante dto clear that u if that's what you meant?
I know that - that is the RIAA curve I mentioned but it only deals with attenuation & boosting signals based on frequency, not signal level i.e there is no boost for low signal levels contained in the RIAA spec, is there? I know there is a calculation done about how tightly the grooves can approach one another & this can dynamically alter this depending on the signal level & frequency but AFAIK it was not changing the signal itself just how it was cut?The needle can not follow a high energy groove, its mechanics, digital is not restrained by mechanics,,,,and I talk of the playback consumer side. You can cut a disc with some pretty high energy at say 15Khz but no needle will track it.
I think I'm saying the same thing above as you are here?The system in that way is compressed so the consumer can play it back, when cutting you have POWER AMPS pushing the cut blade sideways but you got to get some recording time on the record to hear more than one song. Speed of the record and width of grooves (energy) is the mechanical limiting factors, fixed by the rpm and play length of the record. Long play records, developed at a slower speed (33.3) result in less energy as well so you can put more songs on it.
And do some research in the difference between a mono cut record and how we use one needle now to convey two channels and you will begin to see why analog via vinyl is absolutely different than via digital. Yes, mids and highs "sound" good, and sometimes better, and it is due to the record, while lows and low mids are not up to digital and it goes back to the cross effects with frequency etc on a record due to the cartridge and the "stereo" cut.
You are also basically correct in that a phantom source
> will be a little broader than a real source, largely due to the fact that
> the localization of phantom sources is somewhat frequency dependent.
> Straightforward amplitude panning will produce a slight discrepancy between
> the localization at low and high frequency ranges, which leads to a slight
> change in timbre (manifests as a slight spectral dip at approx. 2kHz) and
> an increase in the Apparent Source Width (ASW) of the source when it is
> reproduced as a phantom image.
> This is a big problem when dynamically panning a sound as this change in
> timbre tends to highlight the loudspeakers in a negative way and it
> significantly reduces the smoothness of the spatial trajectory
> (incidentally, one the main goals of the Ambisonics spatialization system
> was to eliminate this issue, which it largely does but not without some
> costs).
> Ville Pullki has done a lot of research in this area, particularly in
> terms of his amplitude panning system VBAP. He has also conducted research
> on panning using three loudspeakers (again with VBAP). My recollection is
> that this will increase the ASW even further, and similarly reduce
> localization accuracy. Of course there is a strong relationship between the
> two factors, and the concept of locatedness is useful in this regard.
> Anyway, chapter 6 my PhD thesis has lots of specific references in terms
> of listening tests with phantom sources and the relationship between
> localization accuracy and apparent source width, both for stereophony and
> ambisonics. You can find it here -> http://endabates.net/academic.html
This would seem to be an interesting Ph. D thesis on this subject that I just came across from a guy in Trinity College Dublin (my home town) "The Composition and Performance of Spatial Music"
He has this to say
Can't speak for j_j, but it would be my opinion that low level details are more apparent due to some slight compression needed for making a pressed record playable. Small amounts of compression elevate moderately low level details and increase apparent dynamics without being noticed as such. Not the whole answer mind you just a part of it.
There is less HF energy, less LF energy in vinyl. There certainly is the things mentioned above about crosstalk and intensity differences that are frequency dependent, and as such, less lows and highs is a sort of compression WHEN compared to what digital is capable of. I hear distortions in the low bass in vinyl, but the interactions of crosstalk and intensity and L/R issues make a more pleasant sounding mid to HF (what limited amount compared to digital there is) sound field. And I am talking playback here, not concerned about what is theoretically possible at the cutter but what is the reality at the consumer.
Right, I didn't know this. So we are getting a signal which has been conditioned in more ways than one (RIAA curves) to compensate for the nature of the playback system & delivery substrate. Very interesting. I've never seen this info before (but that's no surprise - I haven't been in the mastering business).
The needle can not follow a high energy groove, its mechanics, digital is not restrained by mechanics,,,,and I talk of the playback consumer side. You can cut a disc with some pretty high energy at say 15Khz but no needle will track it. The system in that way is compressed so the consumer can play it back, when cutting you have POWER AMPS pushing the cut blade sideways but you got to get some recording time on the record to hear more than one song. Speed of the record and width of grooves (energy) is the mechanical limiting factors, fixed by the rpm and play length of the record. Long play records, developed at a slower speed (33.3) result in less energy as well so you can put more songs on it. And do some research in the difference between a mono cut record and how we use one needle now to convey two channels and you will begin to see why analog via vinyl is absolutely different than via digital. Yes, mids and highs "sound" good, and sometimes better, and it is due to the record, while lows and low mids are not up to digital and it goes back to the cross effects with freqeucny etc on a record due to the cartridge and the "stereo" cut.
