MadFloyd,
just read the manual and this is what it says to change the measurement, so you can show Current (amps)/Watts/VA
Cheers
Orb
Thanks, Orb!
MadFloyd,
Cheers
Orb
Maybe the Shunyata products will help here (previously the Triton didn't make any difference and the Typhon was a mixed bag).
Update:
The extension cords arrived yesterday along with the Kill-A-Watt meter.
I plugged the extension cords into two separate 20 amp circuits in my kitchen. Sound was drastically different. Much fuller, darker. Midrange had more weight. Female voices sounded full-bodied etc. Background wasn't very 'black', it was sort of muddy and bass wasn't very textured but overall on the right track.
Of course everytime I've installed new power cords (or even outlets) I get somewhat similar results (overly thick & muddy) until some break-in happens, so the real question was "am I hearing the results of more power, brand new 50' extension cords, or both?"
I left the amps on overnight and this morning listened again. Better, much more engaging even though I wouldn't call the sound quality great (still muddy) and I'm not sure I'm getting the dynamics I should be (but I'm not sure). So with a lot of trepidation, I did the real test - unplugged the extensions from the kitchen outlets and plugged them into the outlets in my listening room supplied by the transformer, praying that I wouldn't hear the same thing. Immediately the sound was thinner in the midrange. Yay.
The quality of the sound is still better through the transformer - i.e. backgrounds more black, so my takeaways are:
1) the transformer does clean up the sound
2) the transformer changes the tonal balance (I assume it's because it's underpowered but I have no experience with one that isn't underpowered)
3) installing two dedicated 20 amp circuits will most likely result in proper tonal balance, but I may not have the cleanliness that I want. Maybe the Shunyata products will help here (previously the Triton didn't make any difference and the Typhon was a mixed bag).
I did try the Kill-A-Watt meter but I couldn't get it to tell me anything other than voltage (I haven't had a chance to read the instructions yet to see if there's a way I can see amperage). It read 123 volts with one amp on and 119 with both on.
Thanks again for the guidance.
Get your hands on a Devialet 200 and see what sort of bass your Magicos are capable of producing. This past weekend I listened to the JBL Project Everest DD66000s driven by the diminutive Devialet 200 and the sonics were extraordinary. That little integrated/DAC is a game change IMHO..
While the Devialet 200 may be great and I can appreciate your enthusiasm for it, mentioning it here is of little relevance to the problems outlined in this thread. The issue is about current limitations, not about which amp is best. If Ian can get his amps to sound great, why should he consider switching?
Hi Ian,
I am glad that a solution to your problem appears to emerge along an expected path. As for the Triton and Typhon, I would assume that they would make much more of difference now that the current restrictions have been eliminated. Yet for your large amps the Shunyata Cyclops units appear the way to go, as BlueFox has them in his system too. I was looking at Shunyata's website, and it states that the "NICs (noise isolation chambers) are patented devices that reduce very high frequency noise in the Megahertz to Gigahertz range without the current limiting and negative sonic affects associated with the use of conventional transformers, coils and ferrite beads" (under link 'features'). Yet I don't know if they give surge protection or protection against maladies such as electrical storms as transformers do (?).
Update:
Isolation transformers don't have to limit current. It sounds like Floyd just needs Equitech to send him the proper size tformer in light of the newer amps, especially since the room is already wired that way.
I know Torus took all my gear and recommended a particular size model.
Thanks, Orb!
I think what es347 might have been referring to regarding the Magico's and the Devialet was not it's superiority as an amplifier, but it's EQ map for specific Magico speakers that Jeff Fritz wrote about doing bass so well. i'm not for or against Devialet and only explain to give context and relevance to es347's comments. and I admit I have not read the rest of this thread so I have no idea whether his comments are on topic.
