USB Cable Choice
Although Steve's opinion is well respected by me especially about MasterBuilt...I think this cable peaks my interest solely based on design and John McDonald.
Audience Au24 SE USB Cable
Find one that shields itself from the power leg, everything else is just a noise tuning system.
I have had good luck with Synergistic Research Galileo and Audioquest Diamond. Shunyata Venom is also good.
Thanks for your replies.
Has anyone listened Goebel, Skogrand, Siltech or Vertere?
Not a cable guy.
I am definitely a Cable Guy, but definitely do not like talking about cables. You can never get past the conductor before hitting IP.
I have tried a few and found that as long as it is shielded there isn't major differences between the good ones I have tried.
Siltech must be a good option but rather expensvie one, is that unpowered usb?
Since many years I use unpowered usb, first it was Jcat Ref, now Polish boutique unpowerered usb , Salamandra ( orange one), recently reviewed by Srajan Ebaen
http://www.6moons.com/audioreviews2/stavessence/1.html
Worth every penny
TotalDAC USB cable which replaced an Audioquest Diamond which had replaced a Wireworld something er' another...
They all sound different, the TotalDAC wins hands down especially for the $.
How much does one go for?
