Like the title says
andI would think with Horns that ss phono would be desired since any noise would be so prevalent and a significant issue for the horns. another way to put it would be any tubed phono would need to be super quiet (read expensive).
that
so maybe Lamm/Yipsilon would work well, but the big multi-box Aesthetix many dozen tubed set-up might not.
and
I think I am going to compare Allnic with thoress and shortlist my valve phono. Then compare with Burmester or such for SS vs valve. Tough to do latter on horns. If I can compare Dart with a valve pre in a horn system, and if Dart is preferred, that could help as otherwise Daart to expensive. One guy preferred it to his Shindo as phono and pre into his Shindo amps. Not that I like Shindo
My cart is Shelter Harmony, rather low output one.Thanks. Did you compare it to other valve phonos recently? Also, is your cart very low output?
Don't want to derail your OP but thought you might like this.
This is my First Sound preamp undergoing its latest upgrade to Paramount status.
And check out the storage capacity for a single stage tube preamp that only pulls 1 Amp of current.
The dual power supplies are not shown - connected via a mil spec umbilicals.
Notice the big-assed Dueland caps along the sides.
How many chassis do you have, Caelin? And have you had AR ref 10, CJ Gat, VTL 7.5, SMC, or VAC in your system
Thai and Sri Lankan has much more chili
