PS: I still have every intention of ordering Stacore platforms for the amplifiers.
Appreciated Ron, you are v welcome! We are starting the 3rd production batch about now.
Cheers,
Thank you, Jarek. Unfortunately I still will not be able to order them for several months.
Spent some time at Mike's this afternoon listening to analog and experimenting with the Takio units.
As baseline, we listened to Mike's NVS turntable with two separate setups:
1. Colibri Stradivariarius on Sapphire Durand Telos arm
2. Goldfinger Statement on stock Durand Telos arm
Initially, we listened with the new Takio unit under the NVS. Very interesting...the baseline sound was improved compared to my previous pre-Takio visit. More air, better articulation and improved frequency extension. I asked Mike to play a number of reference tracks for me, blinded to the arm/cartridge combination. With one exception, it was easy to identify which set up was playing, but the differences had clearly narrowed.
Then I supervised (i.e. I drank a beer ) as Mike labored to place a second Takio unit under his DartZeel preamp. The benefit was immediate and readily audible; akin to giving the Dart PEDs. The basic character of the system was still there; it was just better. Most interesting to me: the differences between the two set ups, though still discernible, had narrowed considerably. Indeed, where previously I preferred the Goldfinger; now the Colibri was slightly favored on most recordings (except on recordings with a preponderance of high frequency energy).
Not sure the I can explain it, but I'm definitely convinced. A very cool upgrade to an already great system.
Hi Mike and Mark
during your listening session did you turn off the Herzan or did you play it both ways, with and without the Taiko Tana in place. For me this is the only true way to know what the differences are. Mark's listening experience was anecdotal as he didn't hear it both ways. I am sure the sound was very good but how can you say with certainty what the before and after effects are. Do what David and Christian did and turn it off and in this case you have to listen both with and without the TT
Just my $0.02
It is good to know what the system is doing in passive mode compared to off and active the difference in sound quality in each state we heard with the AVI is huge and very clearly audible.
david
Pls convince Mike not to let go his NVS. However spectacular his new AS could be, this NVS setup should still be among the best of the best...and a sure thing he could rely on.
Best regards,
Tang
Christian and David,
I spoke with one of the engineers at Table Stable and discussed with him what's going on in the AVI when [ the power is on, but correction not enabled] , and when the correction is enabled
He said when the power is on but not enabled there is no voltage going to the piezo transducers. Mechanically there should be no difference to the spring, damping and mass relationships and motion behaviour whether the power is on or off.
The suspicion then lies with an electric field effect or an electro magnetic field effect when the power to the AVI is on.
One interesting simple experiment to carry out would be to ground the top plate to a good ground socket, terminal in the system / room, and see if that has an effect (positive or negative) on the SQ differential when the power to the AVI is on.
During our experiments with the AVI, we never had a conductive top plate. With all our TS testing we have always had a conductive top plate, and usually connected to a Setchi D-2 via the BNC connector on the back
Edward - EuroDriver
Emile Bok is Taiko Audio
Best regards,
Tang
Edward - EuroDriver
This is very interesting Edward, so if this is the case what we’re hearing could be the effects of this electromagnetic field on the cartridge and/or nearby wires and electronics.
david
let me know what your theory is. I need to do more testing between on/off to make sure I was not hearing things...as Table Stable is suggesting the springs/passive nature of the unit is unchanged from the off to on (but not active) state.
Hard to say Chris because if that magnetic field (?) theory is true then it should be present in active mode doing its thing too but it’s not. We know what we’re hearing and it’s easily repeatable so no guessing there but if this is true then a passive table will sound way better under the AS2000.
david
When the AVI goes active, the power supply noise is applied to the transducers, and that works like the proverbial wet blanket on the sound
Mike, the uber faithful “one woman” men ie one tt, arm and cart, amongst vinylphiles can certainly seem a bit sidelined by the tt/arm/cart “bigamists” and “harem owners” out there with two, three, four arms, and potentially dozens of carts .
