Indeed, only a handful of 2Ts exist, and JC's declining eyesight - effectively blind in one eye - makes it difficult at best for him.
Brian,
Do you think Curl's recent work on the Constellation phono stage is better than the Vendetta?
Spent about 5 hours listening to it yesterday, it's the most detail and fast phonostage that I've yet to hear, it is extremely analyatical however when compared to the ARC Ref3, it lacks the fullness and "bloom" that makes it a more realistic presentation. I will say that the Vendetta comes closer to the sound of mastertapes.
I've recently acquired the SCP-2B (I think); I checked the phase, its correct and the two channels are fused in front though the face plate says 2A. I'm comparing it against my Zanden 1300 MkII and I can tell you, its very very very close. I'm still debating which one to hold on to but compared to the Zanden (retail $11k+) vs. the SCP-2A/B (which I purchased for less than $2K) and that it's at least 15-20 years old, I'd say that its an amazing piece of kit. I'm now wondering if I should go forward with the 2T upgrade. Brian - I'll send you an email as you instructed to secure John Curl's contact info so I can commission the upgrade.
Before one considers A /B comparisons with other/existing MC phono stages ( All the V-SCPs are LOMC ONLY) here is the chart of the models
Good Listening
BruceD
SCP-2A - phase reversed came in 2 boxes
SCP-2B - phase corrected, variable loading, came in a 19" faceplate joining the 2 mono units.
SCP-2C - adds 47K ohm support
SCP-2D - improvement with a drop in distortion, rare and hard to find.
SCP-2T - latest revision by JC, $1500 in mods that will change the wires, FET's, and add expensive Teflon caps, and other proprietary treatments. Need a good unit to get started. The Vendetta and the T upgrade would easily run $4000-5000 now on the used market.
Thanks for that Bruce - the reason being I bought what I believe was an SCP2A - but it has variable loading and a single front plate - indicating it is an SCP2B - that said it has SCP2A on the front plate.
A brilliant technician called Brett Hunnisett in the UK replaced the electrolytics in the phono amp after it blew my main amplifier (£1000 bill ouch) Brett also improved the IC's. These works cost around £350 UKP. I contacted John Curl - a brilliant but perhaps rather shy man - he said just enjoy the phono amp when asked about a Teflon upgrade.
I understand - perhaps from one of the people on this thread - that the original caps make the sound more organic that the Teflon caps - not necessarily a better sound - perhaps a bit more HD/HiFi. I am curious as to the Teflon caps that were used in the T in the event I try and rope Brett into putting those caps into my system.
I had a really nice guy from HK send me the circuit diagram - but on pain of death and respect to John Curl I will not forward this to anyone else.
The most fascinating thing about the stage is that the Hitachi MosFets were 'trace matched'. These FETS are no longer manufactured, but there is some obscure company in the US that bought all the old stocks - that said JC probably had to check several FETS before matching them in groups/batches.
Best single component I have bought yet in my system. Not only superb sounding, but also a component that gives me real pride of ownership given its' rarity and also its notoriety.
John Curl's ability to curve trace and match the Hitachi JFETs (not MOSFETs) is very rare.
Yes, John is shy yet protective, until he knows someone. He's a lot of fun, though.
New here...Found this forum/thread while researching the Vendetta.
I was bored today and decided to see if my Rega 3 turntable still worked after 20+ years sitting in a closet.
Dug out the SCP-2A...it has been hibernating for 20+ years as well.
After listening to digital music for so long I had forgotten how good vinyl sounds.
Hats off to John Curl. That Vendetta pre-amp has thousands and thousands of hours on it, and it still sounds marvelous.
Now if I can just figure out how to hide the dual power supplies in my console...
let me get this right.
you had an scp2a with a Rega planer 3 - no dissing the rp3 - I had one - all the same...
What cartridge are you using?
Why the devil did you have such a fine set up hibernating for so long - you must have a serious digital rig.
Can I just advice you to get the electrolytic replaced. The chap I bought my scp2a of had it working fine, but thee air delivery changed the pressure in the electrolytic (honest - no kidding) and it badly damaged my amp by blowing out a channel.
John Curl recommended new low noise IC's - I got this done at the same time as the electrolytic capacitors. By my reckoning it may have an even better SN ratio than original.
The Vendetta is dead quiet. -85 dB S/N unweighted. If you're getting any noise there's something wrong.I did notice that the Vendetta does have some noise when I increase the gain. I still need to ground the turntable properly, but it may indeed be what you say concerning the caps. We'll see. I recall that the Vendetta used to be dead quiet...and I mean really dead quiet. I need to research what I can do to bring it up to spec
