I'm anxious to learn opinions and experiences by users whom have used or live with a phono stage that has preset or adjustable eq curves and also heard eq applied to a flat file by computer software. A friend with the Channel D L20 phono is promoting the sonic superiority of feeding a flat signal generated by the L20 to the Pure Vinyl software for playback. I have no direct experience with the software but understand it either provides several curves or can gen curves based on user input. The same friend has listened to the Zanden 120 and prefers the software route. He is a headphone-only listener and also values the low noise floor the L20 provides. As some here may know, I am a traditional listener with the GTA3r speakers and am currently using the Channel D Lino C phono.
I recently had the Zanden 120 in my system and without applying any curve aside standard RIAA it is, to my ears, clearly a better phono than the Lino. Once you add the flexibility of being able to adjust phase and eq it becomes even less of a contest. I really like the 120 and it seems a good match with my DHT Coincident MKII linestage. I have also considered the 1200 MKIII and am interested in folks opinions on it as well.
Thanks in advance for any insights...
