They certainly look interesting!Viking Acoustics Tube Master. They are 98db but not horns.
No. If you monostrap a 36 watt tube amp to be 72 watts, if you have it matched properly to the speaker it will be 72 watts. Tube amps do not double power as the load impedance is halved; if they are behaving as a voltage source then they might halve power as the impedance is doubled. Not quite the same.
I used to own CJ MV60 (60 watts/channel), and at the time CJ was very supportive of creating a monoblock configuration out of them by getting a 2nd MV60. I wonder if one could do the same with their current reference level ART 27a amp which is an SET Triode at 36 watts/channel into 4ohms and apparently sensational. That takes it to 72 watts per channel, but as I understand because the amp sees half the impedance load (or something like that?), it actually becomes 144 watts/channel?
If ARC did their homework right this will cause the power tubes to run hotter, since more of the output power is dissipated in them rather than the load. This would have the effect of reducing the output power (that heat has to come from somewhere after all) and increasing distortion. And it would reduce the damping factor. IMO a poor way to go about itYes, it is why tube amplifiers usually have impedance taps in the output transformer - we get maximum power at the best matching impedance.
However sometimes people prefer an non matched set up because of damping - for example many people prefer the 8 ohm setting in Audio Research amplifiers when driving Wilson Audio 4 ohm speakers.
Thank you! Very clear. Well, 72 watts does provide a bit more power if one wanted to go there, and my recollection is that the CJ designs have historically allowed people to do that.No. If you monostrap a 36 watt tube amp to be 72 watts, if you have it matched properly to the speaker it will be 72 watts. Tube amps do not double power as the load impedance is halved; if they are behaving as a voltage source then they might halve power as the impedance is doubled. Not quite the same.
Most tube amps can be monostrapped- that is their outputs and inputs paralleled, thus doubling their output power (in most cases; with one of our smaller amps the output power is actually tripled) and allowing them to drive an impedance half of what they could before. So the 16 ohm taps become 8 ohms, 8 ohms 4 and so on.Well, 72 watts does provide a bit more power if one wanted to go there, and my recollection is that the CJ designs have historically allowed people to do that.
