Not sure if/how any of this applies to cables with hybrid gold/silver and gold/silver/palladium conductors like Echole, Fono Acustica, Gryphon Vanta, and Hemingway Audio. It isn't always possible to match plating. I had a gold Furutech IEC inlet put on my Pathos TT RR when I had it upgraded for example because I was going to be using a Hemingway power cord with gold/silver alloy conductors (not sure what the plating is on the IEC connector-it is silver in color so it could be Rhodium). My Echole power cords have gold/silver/palladium conductors and use Oyaide 046 Palladium over gold connectors (no Rhodium involved). Are there any Palladium IEC inlets? Is it better to match component IEC inlet plating with cable connector plating or cable conductor composition? Not hearing any obvious compatibility issues by the way.
I haven't had audible issues with matching plating or conductors, but I have also never heard anything plated with Rhodium that I preferred the sound of. In their review (link below) of the Furutech FI-50 NCF power connectors with PC-Triple C forged cable Soundstage Ultra found the combination to do many things superbly (my Hemingway power cord does everything superbly) but to nevertheless have a "cool" signature and a slight high end bias, which to my ears is characteristic of Rhodium. Every Rhodium plated connector I've listened too has lacked a little of the natural warmth of music compared to its gold plated counterpart. When I was having my Pathos TT upgraded I therefore picked the Furutech FI-09 gold over copper IEC connector. Since I have two gold and two rhodium plated Furutech GTX-D outlets in my Bybee Stealth Power Purifier I have been able to do direct comparisons of my power cables (Hemingway Audio Z-Core Beta, Echole Omnia and Signature, Verastarr Grand Illusion, Audio Magic Clairvoyant Liquid Air, and Isoclean Supreme Focus) in each type of outlet. Without exception I have gotten more natural and enjoyable sound via the gold plated outlets without missing anything in the way of resolution. Currently I have all of my components plugged into the gold plated outlets and Nordost QV2's plugged into the Rhodium plated outlets. Finally let me say that with all of the isolation and power purification measures I have taken I do not need to have NCF in my connectors (I have the NCF Clear Lines and Booster Braces). Appreciate the demo offer but I am set when it comes to power cables.
I've been demo-ing/comparing cables, connectors, and components for 40+ years. I've listened to a shitload of different plating combinations and prefer gold with top tier gear over rhodium. In my system I am not missing any detail. And let me be clear - I have never had an all gold conductor system. My Echole cables all have Palladium over gold plating (Oyaide 046) because that's what they use. My Hemingway Audio cable has silver colored connector plating which could be Rhodium - I don' t know. Hemingway makes their own connectors and there's no information at the website about plating. But when I've been in a position to choose plating, as with the power conditioner outlets and IEC inlet I've chosen gold because I preferred the sound.
@DaveC
Dave, would you have an opinion were you to choose between FI-48 NCF Vs FI-50 Piezo Carbon ( Non NCF)
Installed Furutech FI 09 . Delrin used for mounting block. Notice use original mounting holes . Can undue this mod , and return it back to stock if needed.
I installed Furutech FI 33 NCF inlet and FI E30 outlet on a DC Blocker.
It seems to take forever to break them in. I really hate it. Changes from good and open sounding to more closed in, with lack of bass and harsh highs. The holographic soundstage and the dynamic potensial is not there, even after weeks.
Luckily I have been through this break in process with Furutech equipment before.
Honestly, I think it requires more time than people realize.
I would say give Furutech cables, connectors, outlets etc. 2-3 months in the system before you reap the awards.
Thanks for the advice. It is now 5 weeks since I installed this DC blocker with Furutech NCF inlet/outlet in my system.Yes, that's a great description of the Furutech rhodium plated copper burn-in. It's tough to go through!
A couple things can help... I use a cable burner for the receptacles, and it could be used for IEC inlets too but I don't sell may of them, maybe one for every 100 receptacles. Next, you can get a IEC to female AC plug converter and use a cable on a fan or refrigerator for a month or so. You can also wire up a converter using the receptacle you want to burn-in.
