Apologies for any delays--all messages responded to on all platforms. This is my first day back in the office after being pretty sick... All good now though!I PM'ed you the other day
Mr. Golum, may I ask what speaker cables you run into your Vienna speakers?Not to open a new topic - seems like FTA is also a viable option in other type of cables...
https://www.hifi-advice.com/blog/re...ews/final-touch-audio-ganymede-xlr-interlink/
Hi;Mr. Golum, may I ask what speaker cables you run into your Vienna speakers?
Entire line is called Ganymede from RCA, XLR and Speaker cable. Speaker cables are done as per order and hence not on the website.Interesting, I had thought the Ganymede was to connect the DAC to the Amp. I didn’t see speaker cable on the web page.
Thanks for that information, sir. As we have the same speakers and the same brand DAC, I value your opinion. PS, I am upgrading to the Horizon. The USA rep (Fred) is very persuasive.
Is it with the 5V line/trace or is it with the 5V line cut? Lampis sound better with the 5V line cut.I just re-acquired an FTA Calisto cable for my second system. It sounds good but not quite as I remember it previously. I am assuming it's broken-in, but does it need to settle down in mys system to sound it's best? Lucas Domensky told me never to judge cables as soon as you insert them into your system, even if they had been broken in previously.
Thanks.
Our main site is here: https://dsgdistro.com/Where is the Destination Sound Group’s website? I’ve yet to find it.
https://dsgdistro.com/ from my Safari this link opens to dangerous sites, it re-links you to different placesOur main site is here: https://dsgdistro.com/
Final Touch Audio cables can be ordered from the "Final Touch Audio tab on https://www.lampizator.com/:
I apologize for the technical issues. It was brought to my attention that Microsoft recently turned of TLS1.0 and 1.1 enabling it in windows under internet options/advanced settings makes it display properly again, but I will have to reach out to my provider and have them update the certs of whatever the issue is.https://dsgdistro.com/ from my Safari this link opens to dangerous sites, it re-links you to different places
I managed to find the site thru google and after that i can NOW enter directly from the same link ...maybe i have a virushttps://dsgdistro.com/ from my Safari this link opens to dangerous sites, it re-links you to different places
Thanks for the clarification, i was going 007 mode here... uuuff !I apologize for the technical issues. It was brought to my attention that Microsoft recently turned of TLS1.0 and 1.1 enabling it in windows under internet options/advanced settings makes it display properly again, but I will have to reach out to my provider and have them update the certs of whatever the issue is.
In the meantime if you re-enable TLS 1.0 and 1.1 (or view on cell phone) it should be working.
Fred
