I've read so much about the benefits of RELS 6 Pack Array. To be honest I thought it was hyped up BS. Not to mention the imposing nature of 6 Carbon Specials kind of turned me off. Finally my curiosity overcame me. I called Tom at ONEST AUDIO. I never met Tom (a friend recommended him) I must say he was a pleasure to talk/work with. What I really appreciated about Tom was he doesn't come across as "the expert". He just shares his knowledge. I came right out and asked what do you think? He didn't say oh its going to be great! He said if you want to do it let me know. It took less than a week and 4 more Carbon Specials were delivered. Great transaction!
I got them all stacked, the connecting cables were delayed (FEDEX) 2 days so I got to stare at the imposing "stacks". Yesterday the connecting High/Low level Cables arrived from REL. Clay at REL gave me several tips. Firstly you want to individually set each High/Low Level and Crossover. The whole concept is the for the 3 per side to work in unison, not attacking each other. It takes methodical incremental adjustments. Bottom Left (anchor) last count was 18 adjustments and the right side will NOT be identical to the Left. Its a daunting process! While your doing it your thinking this was a mistake. BUT once you get them in SYNC its a "I get it moment" I used a pad with a diagram of the six stacked. As I made adjustments I would write them in and highlight the last added change. If you don't do that you will loose your mind!!
I went back to the single pair and as you can imagine huge difference! Still getting my head around this. The midrange is special, snapping of fingers, drumsticks popping off of each other, the stick hitting the skin. Its almost as if the bass is providing more delicate nuances.
With Knee Replacement surgery tomorrow I doubt I'll be doing much listening. I frantically wanted them set up and dialed in as closely as possible before the surgery. I could only imagine coming home and staring at them without knowing what they sound like!
