Remind me what going Reference brings you ?2500 euro. 1500 euro for valve PSU that can be used with the stereo as well. Reference is 6.5k euro
Miyajima Zero is nice but their own Infinity goes further.I like the Miyajima Zero, but the Vyger red sparrow plays monos better, and plays stereos. So why have the mono? Ok, if someone insists, fine, a second arm.
For me mono is only old, which were recorded in mono. Not monos from the stereo era.Miyajima Zero is nice but their own Infinity goes further.
I hope you get a chance to try a Tedeska Mono someday; preferably one built with his modern styli* and his silver winding. These are pretty great.
( * good for all but the oldest mono )
My Audio Guru says oh no oh no to the Eminent EX. "You have the correct cartridge from MSL". I have only heard the Platinum Sig. Others praise the Eminent EX. It is Stereophiles' Herb Reicherts' favorite cartridge that he judges all others against. My personal opinion is MSL only makes excellent cartridges. My first demo of my turntable was with the platinum so I said okay, that works. I am so not shopping for a replacement. You might be fine right where you are at. I wish I knew the sound your cartridge!I am just wondering whether to upgrade my Ex or not, and how much better a MSL Platinum Sig. or a MSL Gold Sig. will be over what I am hearing from my Eminent Ex ?
Hi 'aangen',My Audio Guru says oh no oh no to the Eminent EX. "You have the correct cartridge from MSL". I have only heard the Platinum Sig. Others praise the Eminent EX. It is Stereophiles' Herb Reicherts' favorite cartridge that he judges all others against. My personal opinion is MSL only makes excellent cartridges. My first demo of my turntable was with the platinum so I said okay, that works. I am so not shopping for a replacement. You might be fine right where you are at. I wish I knew the sound your cartridge!
IMHO/IME:Hi 'aangen',
That is interesting what you mention here about the Eminent Ex from your Audio Guru.
Likewise I would love to hear how the MSL Platinum sounds too.
Would be great to do a direct A to B comparison of the Eminent Ex, Gold Sig. and Platinum Sig.
I still have quite a shopping list for items I want to buy for my analogue set-up including upgrading my Eminent Ex sometime in the future and am a bit stuck with reasoning (scratching my head) which are the best to buy first items to get most upgrade in sound vs money outlay (if any of these items do actually upgrade the sound I am hearing with my current analogue set-up) i.e. (in order of money outlay) ;
1) Buy a Kuzma Ebony Record Spindle Weight (instead of using the original Kuzma XL DC screw down brass weight - which I don't have any problems with, on the basis that from reading online reviews from professional Reviewers and WBE Owners that the Ebony is superior to the original brass screw down clamp resulting in better sound quality.
Side Info for 1); At the moment I am using with great effect different thicknesses of neoprene Penny Washers (from 0.5mm up to 2mm thicknesses depending on record thickness and degree of warp) that I bought on Amazon at a crazy low price underneath the record which helps flatten the records with the original brass screw down clamp. These Penny Washers have an 8mm internal hole diameter for the spindle and 30mm outer diameter.
2) Buy a Kuzma Outer Ring Clamp for my XL DC (to help flatten the outer edges of some of my slightly warped records, although I can now flatten my records with the neoprene Penny Washers as described in 1) above)
3) Buy a used 4Point 14" to replace my 11" (on the basis from reading online reviews from professional Reviewers and WBE Owners that the 14" is better and an upgrade to the 11")
4) Upgrade my MSL Eminent Ex to say a MSL Gold Sig. or MSL Platinum Sig. (on the basis that I am assuming that upgrading to a more expensive cartridge will be an upgrade in the sound I am hearing)
5) Buy a used CH X1 for my CH P1 (on the basis from reading online reviews from professional Reviewers and WBE Owners that connecting an X1 to the P1 improves the sound and performance of the P1)
Problem is, I will have to buy all of these new and second hand items blind (as near impossible to demo these items with my current system set-up at my UK base) and therefore will have no clue of any sound improvements they may make.
Hi 'mtemur',IMHO/IME:
- Don’t do first 3.
- (4) Cartridge is a consumable object. Higher priced one doesn’t have to sound better than a lower priced one. There can be big differences even between same models cause quality control is very poor among cartridge manufacturers in general. The same is true for stylus and cantilever manufacturers too. Consider upgrading your cartridge only when you have an opportunity to audition at your home or a place you’re familiar with the sound.
- (5) Do buy CH X1. It’s not necessary and doesn’t make a huge difference but still makes an improvement. You can sell it if you don’t like it.
Hi 'SOS',Just a quick note regarding the MSL cartridges (Disclosure: recent dealer for them). I initially bought the Gold Sig and it was wonderful, very musical and dynamic with lots of detail and great harmonics. A customer was over and heard it and wanted one but just a bit to much $$ so I offered my own to him at a discount (only had less than 40 hrs on it...probably still not fully broken in). He grabbed it and I bought the Platinum Sig. The Platinum is the more accurate cartridge and has even more detail but all in all very similar BUT I did prefer the more musical Gold Sig at least in my system. This on a Stabi R / Safir combo. One thing I did find strange was the Gold took playing for close to 25 hrs before opening up and "singing" where the Platinum sang much sooner. Also these cartrdiges are VERY dependant on precise VTF.
Have you tried speaking with Kevin Scott at Definitive Audio? As well as his own wonderful Living Voice speakers, he is the Kuzma dealer in the UK and can help you out with 1-3 above.Hi 'aangen',
Hi 'AudioAbe',Have you tried speaking with Kevin Scott at Definitive Audio? As well as his own wonderful Living Voice speakers, he is the Kuzma dealer in the UK and can help you out with 1-3 above.
In addition, until last year, he was also a CH Precision dealer, so will be able to give you a view on the CH X1 quandary.
He's an absolute gentleman, and you can do much worse than spend an afternoon at Definitive Audio listening to great music on some pretty special equipment.
Amazing music machine S7 Simon Yorke, simple no complex electronics, just move the belt for a speed of 33.45, 78 simply in the tonearm setting. sit back and enjoy the music. fantastic symbiosis with allaerts or koetsu carts.
invest the rest of the money in a good phonoamp . moon lp610 or tube tron 7 ultimate sounds great with both.View attachment 106992
