In case folks are not aware of this site linked below and are interested in very thorough measurement data for many different Subs its a good read. The link below is for the JL E110 previously mentioned. No REL tests though. They do have Funk Audio tests..FWIW
You can even overlay multiple Subs to compare their measured performance.
I have no affiliation with the site linked but I did find the information very helpful during my own purchasing decision a few years ago.
I think you might find that the need to drop big $$$ on a Sub is not necessary unless you just like the brand/style of a particular offering. The reality is, there is only so much you can do with 1 Sub of any size or price unless you have a very small listening room.
The other thing to consider is your intended listening level. The smaller displacement Subs lose steam at elevated listening levels (Say 90db or so) and assuming that maintaining low distortion levels are a priority. This is often overlooked.
One cure for that is to keep adding additional smaller Subs (Assuming you have enough Channels to do so) or start with bigger ones from the get go. I went the later route.
Data-Bass: Subwoofer Measurements
data-bass.com
