K Kttran New Member May 28, 2023 1 0 1 55 Jul 3, 2023 #1 Need help if anyone ran into this problem. I bought A3500 amp not to long ago, it was fine for few months until fuse keep blowing when I turn on the amp.
M MarkusBarkus Well-Known Member Feb 6, 2021 1,035 1,692 258 66 Jul 4, 2023 #2 @Kttran have you contacted your dealer/seller? Blowing fuses is not normal for any product, and it indicates a problem. Do you know for sure that the fuse ratings are correct for the amp, if purchased used? That spec should be available somewhere.
