A2169 model.. A search on ebay for A2169 and setting a filter to "new" will bring up a lot of fact new A2169 models.How does one differentiate the latest Apple 4k streamer, from the (better) previous generation?
Thanks.....
Thanks.....
You would think huh ? But Noooooo,,, the LGs can somehow find the HDR flag anyway and flip. Because of all that weirdness I have found its best to just give in on the LGs and do Dolby Vision... Plus the LGs seem to have a intentionally bad SDR setup,,, to maybe make Dolby look good ? hahaha..If you set it to SDR and turn off Match Dynamic Range, it should stay in SDR.
Could they have something hidden in the service menus about that? Or possibly did they use a really cryptic (meaning Poorly Labeled) setting in the standard menus? On the Sony side, I've seen reports that changing a serial communications setting impacted HDMI, for the better. (I believe that disabled some CEC comms that were doing "magical" stuff.)You would think huh ? But Noooooo,,, the LGs can somehow find the HDR flag anyway and flip. Because of all that weirdness I have found its best to just give in on the LGs and do Dolby Vision... Plus the LGs seem to have a intentionally bad SDR setup,,, to maybe make Dolby look good ? hahaha..
Oh cool. CEC Free ! hahaha.. Interesting..Could they have something hidden in the service menus about that? Or possibly did they use a really cryptic (meaning Poorly Labeled) setting in the standard menus? On the Sony side, I've seen reports that changing a serial communications setting impacted HDMI, for the better. (I believe that disabled some CEC comms that were doing "magical" stuff.)
One thought might be to try one of these on the ATVX (I'm using one without any issue... though I have a Sony tv):
But even with that, I'd still set Match Dynamic Range to Off to make sure the ATVX doesn't send an HDR signal.
The thing is,, if i set the ATVX to SDR and disable dynamic range content matching,,, you would think,, NO HDR/DV would get thru. But something does and the LG can see it. It is just metadata. So I was thinking that the ATV is just setting a HDR/SDR flag to SDR. And most displays adhear to this flag. But the metadata persists. SOOO if a display ignored the flag and just flipped modes when it saw the data and ignored the flag,, then that would explain what i saw.
Yes there could well be some deeply buried service menu setting on the LG. Dolby Vision was, ok,, on the LG. SDR would have required a serious calibration as it was no where near correct. SDR looked terrible. Like intentionally terrible. But Dolby looked great. Imagine that.
I would like to have hands on with the Panasonic OLED. I wish they would sell them here. That is so annoying.
I have a Sony 83” Master Series A90j. The settings for the Apple TV is 4kSDR, RGB high and the match content settings set to on. Passes DV and HDR 10 through just fine. My set does have a full calibration. These settings are those recommended by the calibrator.
I have a 2019 65" LG C2 OLED. Earlier with the Appletvx it did auto flip from the "Cinema" setting to the "Home Cinema" setting, which I noticed as the picture became too cartoonish and the tv was changing from 24 Hz to 60 Hz. But I put it back at "Cinema" and since then no issue and my LG has not on its own changed from 24 to 60 Hz or from SDR to HDR.
When I had my Lumagen 5348 in the system recently for about 2 weeks, I had no issue with the tv changing SDR to HDR or vice versa. Lumagen recently had a firmware upgrade which I could see improved its HDR tone mapping a fair amount. Nonetheless, SSR with the Appletvx still looks remarkable and better. Even with the Lumagen in the system. And also, perhaps even more so, with the Lumagen NOT in the system.
I suspect that when you watch different programs with different refresh rates, Dolby Vision, HDR, SDR, etc. that the LG may memorize what you have it set to for picture so when it next appears you get it again. Just my suspiction. Especially as I have had no reoccurence of the issue in quite some time.
I love the Lumagen 5348 for use in my theater (currently being upgraded/renovated), but I don't find visually any noticeable video improvement having it in my basement system with my LG OLED.
There is something new for the ATVX...
It turns out, even tho its hard for me to imagine why, but how you feed the ATVX with its network MATTERS to pic/sound. Others have mentioned this in this tread that, amazingly, ethernet cables seemed to matter. Its hard for me as a engineer to say there is a technical reason for this, but, I too have heard and seen it. So its hard for me to deny when I can tell differences even in a blind AB.
So.. Bill, my distributor, pushed me into making a ethernet switch. I complained and argued it can't really matter that much. BUT.. I made one. I decided to just max out every electrical parameter possible. Just go insanely overboard in every area. I focused on the technical aspects of TDMS signals used for ethernet, optical, SFP+, Direct attach SFP.. I made a switch just seriously lab grade in its output and insanely overboard in any way I could think of..
I sent this off to Bill and some others with super high end systems.
Well I will be damned.. Not only did they all like it VS other switches in ABs, they separately all described the same kind of improvements for high end audio server/DAC use. Not just streaming off the net, but using the switch between a local server ( like roon ) and a DAC. It even worked well to isolate a server DAC hooked up USB. I even created a special access point for audio use.
Recently, some of these same people plugged in the ATVX to it and said things like "OMG - Its twice as good"..
SO... Apparently... Feeding the ATVX with a super clean ethernet signal and doing it from a isolated "clean" network matters.
I have no technical reason I know of currently WHY a super cleaned up ethernet signal and switch chip would make such a difference, but, everyone so far who has played with it says it does. I admit, I saw it too.
Bill talked about the switch X and about the ATVX towards the end of this vid.
When you purchase a switch X does it also come with the Aruba?There is something new for the ATVX...
The video wasn’t completely clear on that point. Bill seemed to indicate the Aruba WAP was being packaged with the Switch X.
Can you clarify? Other than the picture on the homepage, The Aruba is not noted on the dejitterit.com website.
Can you elaborate on the modifications and or upgrades being made to the Aruba WAP or will there be a separate page elaborating on those details?
Do the power supplies for the AppleTV X and the switch have multiple rails that could power a separate main router forexample that would sit next to the Switch X?
Go to Chris' Appletvx youtube channel fo rmore info on stuff:
AppleTV X - YouTube
I watched the video and Bill simply got into different but related subjects. I didn't get the impression that Chris sells or modifies the Aruba for wi-fi - simply that he recommends it. And Chris has a video on his Appletvx youtube site evaluating several wi-fi routers and explains why he recommends the Aruba.
In my case, my AV systems are all hardwired back to the cable modem in my theater room; and my wi-fi routers are all a good distance away from my audio components so I'm not concerned about pollution/noise in my av systems.
The Appletvx linear power supply has one very short connecting cable built into it which connects to the Appletvx. You can't power more than the one Appletvx with the power supply. My understanding from Chris (also over at the Audiophile Style Uptone Audio Forum, discussions by John Swenson who designed and built my Uptone Audio Etherregen network switcher) is that connecting more than one component to a LPS defeats somewhat the noise reduction benefits of using LPS in the first place.
At 21:25 in the video by Bill Parish his statements sure sound like he both sells the Aruba and some modifications are done to it. He then talks about plugging it into the LPS that looks like the one from the AppleTV X. So he gives the impression this is a product being soldGo to Chris' Appletvx youtube channel fo rmore info on stuff:
AppleTV X - YouTube
Per the debit Eric.com website, The switch X and LPS are $3500. Not sure whether the Aruba is included in that cost or notInteresting. Cost please for the Switch X, LPS and Aruba?
That should read dejitterit.com websitePer the debit Eric.com website, The switch X and LPS are $3500. Not sure whether the Aruba is included in that cost or not
