Best Material for Filling Hollow Rack Legs?
ddk
6,261
4,043
995
Utah
In all sincerity I don't get the allure of Herzan brand for audiophiles. Why bother getting something that one already knows is going to have problems when there are great proven products from Stacore, CMS, SRA and even Sound Anchor for high quality products at bargain pricing given the context here?
david
sbo6
1,678
605
480
Round Rock, TX
The materials I know of are lead, sand, rice, steel shot (various sizes), clay, wood and a purpose - made material called Atacama Atabites. I am in a similar scenario but I have decided that for my DIY 1.5" thick shelved birch rack with steel posts that I will replace them and kill kill 2 birds with 1 stone by using dark walnut wood posts that will be 2" longer for the bottom shelf and 1" longer for the top shelf (better equipment clearance). Hope this helps.
16,216
13,681
2,665
Lava! ;)
is this an active stand?
david
No, not active. It is the same as the passive stand Christian had Herzan custom make, except I am specifying three inch square legs.
ddk
6,261
4,043
995
Utah
Wall thickness also matters, specify 1/8"all around or alternatively look at Sound Anchors.
david
Stacore
641
196
180
Gdańsk, Poland
stacore.pl
The legs of my current stand are three inches square. Many years ago I filled them up with sand to maximize damping and to minimize any resonance in the legs.
But sand is kind of messy to work with. What are other options for filling up hollow legs for damping purposes?
What about solid stainless steel ball bearings?
What about little balls of lead?
Dear Ron,
In general in vertical sections (legs) you want MASS! Sand is very good from our (and not only our) experience. It's messy but you do it once anyway.
The sand cannot be too fine as it will the solidify and start transmitting ultra low frequencies through it.
Ever walked on a beach and felt that dull thump on a solid sand parts? The sand particles need freedom to move one against each other and dissipate the vibration energy through friction.
Actually fine gravel is better and it is what's used e.g. for damping roller coaster structures.
Make sure it's dry - aquarium shops can help here. Lead shots is another great material, unfortunately unavailable in EU. Lead is
the best damped metal. By itself lead shots can be not so efficient as the
shots have a tendency to clutch together and you somewhat loose the friction action. Therefore I'd suggest mixing coarse sand with some
lead shots to break any homogenity of a single material alone. And add more mass :)
When filling the legs, do it 3/4 of the height max to leave some space for the filling to work.
Cheers,
tima
5,861
6,935
1,400
the Upper Midwest
In all sincerity I don't get the allure of Herzan brand for audiophiles. Why bother getting something that one already knows is going to have problems when there are great proven products from Stacore, CMS, SR and even Sound Anchor for high quality products at bargain pricing given the context here?
david
Don't forget SRA.
Chris Brady (Teres) might recommend lead shot in oil. :-0
BruceD
1,516
587
540
Jarek has the goods I'd go so far to say--- over the last 40 years I've filled the various Stands I've owned with
50% #10 lead shot and 50% coarse Silica sand leaving say 3 to 6 Inches Clear at the top of each strut.
Yes the pure lead shot is hard to obtain now but I've kept my original 40KG in containers (but not the sand!) I was lucky in the late 70's I lived in sight of a Shot Tower
and All gauges of Pellets were available for self loading then:)
I've tried Kitty Litter /Rice--- the above remains #1 choice
YVMV
BruceD
pjwd
518
357
298
Brisbane
YVMV
BruceD
Bruce - you can still buy pellets in Aus from gunshops - I would be amazed if that is not the case in the USA - when I used spherical glass basting beads in the mix the idea was to prevent the particles from locking together which they do when they are asymmetrical like sand or lead shot
no one ever does comparative analysis of these options as it is a huge project - you just choose your poison and are pleased with your results
however I am sure that suspending lead shot in a flexible compound that also adheres to the walls of the tube would be the best option
I agree with ddk that wall thickness is important and would go harder - 5mm or higher - the material cost is small compared to the labour - the only issue is moving it after you build it :)
also if you were thinking about modes you might want to make the section rectangular - if you were thinking about stiffness you would make it round
I really do not understand why you would leave any portion unfilled
it can be a rabbit hole
Phil
16,216
13,681
2,665
david
David, I have no particular affinity for the stands of Herzan, but I ordered a TS-140 for the Io control unit. The active isolation platform should sit on a solid surface (not “filter” shelves from CMS or HRS, and no cushion shelves by SRA). Based on Christian’s report on his Herzan stand it seems to be pretty solid, and I thought I would increase its rigidity further by specifying 3” square box legs.
So since I wanted a simple rigid stand for the Io for the active isolation platform, it made sense to get a second stand matching the first one. That’s all. This is how I came up with the plan to order two custom Herzan stands.
Actually, I really like the audio racks you have, but you told me that company is out of business?
SMKL
75
the sound of Tao
3,641
4,896
940
Another +1 on a shot plus sand mix for infill for stands with square hollow section steel posts.
A mate who had gone into a bit of a side business of fabricating custom sound anchor and target style stands back in the late eighties early 90s made me a set for my Proac Response 2s, he then suggested I try a 60/40 sand and lead or steel shot mix as fill.
I took his advice so can’t say that I have tried any other infill combinations or quantities but they were fantastic in use. Recently used the same combination on the Harbeth 30.1s and they also sounded wonderful and I have heard these in comparison with some of the various wood stands available and the sand shot filled steel stands gave a better balance overall, huge life and immediacy plus they dug more deeply into the lower register and were more coherent overall top to bottom as well.
Just about to do myself some custom steel stands for my new Harby 40.2s and I will aim to fill these with a sand shot combo as well though if I get time I might play with some extra additives like crushed tourmaline and copper tubing and sheeting and maybe constrained layer damping for the top plate with either copper or calcite crystal, and marble or glass slabs or delignit panzerholz.
the sound of Tao
3,641
4,896
940
I have been thinking of damping a pair of hollow steel stands but unfortunately, it’s completely sealed. Has anyone tried using damping pads such as Dynamat to strategically stick onto the sides/base of the stands? http://www.dynamat.com/ I am likely to head in that direction.
This? http://www.dynamat.com/architectural-home/architectural-home-dynamat-xtreme/
http://www.dynamat.com/automotive-and-transportation/car-audio/dynamat-xtreme/
Could you try getting them drilled so you can fill them and have a listen, even get something so you can then plug them with a stainless threaded diode so you could add spikes at the same point. Either way I’d drill them and play with some sand to start with.
SMKL
75
Thanks
Albertporter
185
19
1,575
Dallas, TX
www.albertporterphoto.com
I tried several fill materials in my 4” diameter stands. Began with nothing and then tried fine white sand, kitty litter and lead shot. Of these the lead was poorest performance, white sand was OK but by far the best was Silica. The black Silica used for sand blasting.
There are regulations on this material so I might not be as easy to get as some filler choices.
musicfirst1
504
310
395
Canada
www.musicfirstdistribution.ca
I went with epoxy coated aquarium gravel, not as messy as sand and with similar bulk density, stainless steel shot might be 'better', but plain steel shot will oxidize (rust) with time. silica and lead have long term health concerns
MTB Vince
187
222
128
59
Dundas, ON Canada
All the smaller tubing in my custom thinwall stainless rack were filled with expanding spray foam.
The threads of the adjustable feet were capped so I could fill the open tops of each 3" square leg with sand
A BDR puck floats on top of the pillar of sand contained within each leg. Then an additional BDR cone and puck supports the carbon composite top shelf. Each rectangular Corian platform floats on a bed of sand contained in the three wells molded into the top shelf or the six individual Corian sandboxes beneath.
Foam weatherstripping affixed around the perimeter of each top plate contains the dust from the sand while still allowing the top plate to "float freely" on the sand. Each of the 6 individual sandboxes sits on a trio of threaded leveling adjusters.
Reactions: Folsom
dan31
1,020
369
1,653
SF Bay
I used kitty litter as it’s affordable and limits the mess. I think most of us pick a material and go. I would hate to fill it and then unload it only to refill it. Albert has given a fair comparison. I would follow his lead unless the manufacturer provides guidance.
sbnx
1,207
1,361
290
I knew a fellow audiophile back in the 90’s who had custom stands for his spica TC50’s. He had the 5” diameter steel post filled with transmission fluid and welded shut with the top plate. The stand was very heavy and inert.
turns out he was way ahead of his time in vibration management.
