Clearaudio MC stylus guard
JeffL
33
10
73
81
Kent, UK
Hi all
Just registered with the site so hope I don't break any rules... Does anyone have any experience with Clearaudio MC stylus guards? I've recently damaged a Davinci V2 cartridge while fiddling with the guard (it always seemed v tight so I only fitted it while installing new kit) and am now desperate to avoid repeat with replacement cartridge. The instructions are a bit odd. Is there a better guard on the market that will fit? Thanks very much.
Hi, I have a Clearaudio Goldfinger Statement. I don't like the stylus guard or the packaging. I love the cartridge and the sound.
I do not think there are aftermarket guards. I've owner Lyra's before and their guards were outstanding and easy to use. I also have an Allaerts cartridge. It has no guard.
Reactions: Addicted to hifi
Thanks for this -
Many thanks for this - saves me the trouble of hunting for a better guard. Now have Titanium V2 safely fitted sans stylus guard and working beautifully. V envious of your wonderful system(s) - I think I need a larger house so I can enjoy mine more!
:) the room is everything ! Please post your system when you can (or add a few comments here-mostly I'm curious), your Titanium v2 is a killer cartridge. I'm guessing you have a pretty nice vinyl set up...Also if this is your first WBF forum post, welcome. Lot's a great folks and points of view here!
Reactions: JeffL
Hi there - apologies for not knowing/using your name but that is presumably forum etiquette! I have a main system for serious listening and a smaller one I put together to go on using a couple of items I couldn't stand to get rid of. Main system is now Boulder 1110 and 1160, Boulder 508 phono-pre, Linn LP12 and Ittok LVII arm (cherished and regularly serviced), Clearaudio Titanium V2, and Marantz SA10 CD player. Speakers are Triangle Magellan Cellos. Room is about 30 square meters - UK houses are sadly on the small size. In the study is my little system: a Rotel amp and KEF speakers so that I can still enjoy a Musical Fidelity Nuvista CD player and - star of the little show - a Garrard 301 with SME 3012 Series II arm (both bought in 1964) and Denon DL103 cart, running through a GSP Elevator/Era Gold combo. I just love watching that black vinyl playing on the Garrard!
Thanks for the warm welcome. I'll try not to become a bore but it's great to have access to all this wisdom and knowledge. Happy listening.
Jeff
Jeff
Meant to add that I run a Blusound Vault 2 through the DAC in the Marantz for Hi res streaming from Qobuz and Tidal and also as a library for Cds, though the actual CD played through the SA10 sounds a bit better than the copied version on Vault.
I'll confirm that the Clearaudio stylus guards are really not very safe to install and difficult to use. I have Goldfinger Statement as well. My Koetsu stylus guards are just as bad.
Lyra have a milled slot to slide the guard on so they are precise and safe to use.
Welcome to being indoctrinated into the stylus repair club. It is bound to unfortunately happen at some point in your analog journey.
Thanks for this. I thought it was just my stupidity/clumsiness to blame but it does seem to be a design issue. The Clearaudio distributor himself confessed to doing the same thing. Paradoxically it was a stylus issue that got me started on decent audio years ago, when I realised the pickup in my prized little record player couldn't actually track records with anything more than mild bass content. But the Davinci V2 is the only audio item I have actually wrecked...
I hope not to have to renew my SRC membership any time soon!
Jeff
I've only had 3 tables in my life. A Linn LP 12, a SME 20/2 and my current Grand Prix Audio. I've read the LP12 upgrades over the years we're significant improvements. Looking back I should have kept the Linn and the SME. Just so many memories...
Yes the SRC club isn't my favorite place to be hanging out !
Clearaudio gold finger is the best sounding cartridge I have ever heard.
I know a few friends broke the cantilever off while trying to put stylus guard back. It is stylus killer not guard.
You better forget the guard ?killer?altogether, put it back in the box not to the cartridge.
