That’s the Key .. I owned the Equitech ET2Q for over 20 years.. The secondary winding has a higher output. The unit if fed 120v, will output 124-126 V, half that on each leg. They do this to keep the voltage from sagging under load. So if you lightly load it, you will get a higher voltage, even a medium load will still yield more voltage than the incoming line..Measure the voltage output of each at that location.
Also how consistent was Ron’s placement along with things in the room?
When I removed my BAT mono amps from the system, the unit kept delivering 125+ volts, which was too high for my low powered tube gear.
I had This issue with my ET2Q which added 4-5 volts to compensate for load.. The equi-tech was already getting 124 volts from the mains In the winter months as nobody was loading the power down with HVAC units. I put a 20amp VARIAC in front of the Equitech to lower voltages for my tube amps, pre, etc..The sound is louder because the voltage on the output of the transformer is higher than the output from the P10.
You do pay attention well. The dinali is a very good passive filter does little of any harm . But I would not use it to feed a power conditioner as you found out.I have a P10. I have my digital gear on it. I had to move it onto its own dedicated line. I had it on a dedicated line with a Shunyata Denali. I found it was negatively impacting the Denali and my analog gear (the Denali was feeding the P10 and it was still affecting the line when I moved it to the same wall plug as the Denali ).
I also found the adjustments for sine wave and pulse wave need to be set carefully for best (or worst) effect of the P10. It can sound bad.
I also found having SMPS's on the P10 was not a good thing, it soaked up the grunge and passed it along to components.
I found adding a PS Noise Harvester to one of the dual plugs on each zone very beneficial, those little suckers pull their weight and way more for the cost.
