New base for Babel is available
New release??Aug.09.2023
The exclusive option board “Babel BASE” for Wellfloat Babel,
Enables precise positioning of Wellfloat Babel at the accurate center of gravity using the attached movable attachment on the backside and the included push-pull gauge.
Compatible with audio equipment of any bottom plate shape, including spike legs.
Specification
Design: Adjustable center of gravity
Materials: Stainless steel, aluminium
Dimensions: 480mm X 450mm X 15mm
Weight: 6.8kg
Accessories: Push-pull gauge, Positioning template
