Help: Qobuz stopped working
sbnx
1,240
1,429
290
Hello all. For some reason Roon stopped working a couple days ago. I had to re-install roon. But after the re-install Qobuz won't stream music. I can see Qobuz music and select a song and press play but it won't start playing (Stays at 0 seconds). Roon works and plays files from the server just fine. I have rebooted the complete network (router and switches). I have logged out of Qobuz and logged back in through roon. My Ipad has the latest version of iOS. My server is the Antipodes K50. I have fully shut down and restarted the K50 a few times. The network lights are blinking on the back of the K50 as well as the switch.
Anyone else have something like this happen? Thoughts/ideas welcome.
I would also test to make sure that Qobuz works outside of the Roon environment to narrow the issue down to Roon and not the Qobuz account. Do the Antipods have the ability to stream Qobuz directly without Roon?
My Qobuz account works on my phone. I am listening to it now. I have never tried streaming Qobuz without Roon through the K50. Not sure that is possible.
Reactions: shadowlight
Log out of Qobuz and then log back in, on the K50 and see if that works.
I think I did that too but I will do it again. I have changed/checked so many things hard to keep track of them. I might have to start a list of everything I check/change.
If all else fails. Change your password on Qubuz. Do this as a last resort. This will reset the handshake between the K50 and Qobuz.
