Hyper Sonic X4 Cartridge
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
As with all of my non-loudspeaker products, I only get into something when I find that what is available commercially does not satisfy. I've had a stable of cartridges that I rotate because none of them totally satisfy. The Transfiguration Proteus D was my favorite overall, but unfortunately is no longer available.
However, the Sonic X4 is not just my design. It has a lot of my inputs and nudges in the direction I wanted it to go, but it also has the cumulative set of ideas, ideals and desires that my partners at Hyper wanted. And combined, the four of us have over 150 years of shared knowledge and experience in music reproduction (including recording and music making).
We showed various prototypes at all previous shows that we participated in, and the final prototype was showed at the Pacific Audiofest in Summer. At the recent Capital Audiofest, the first production unit (Serial No. #001) had a few of my friends awestruck at what it could retrieve from vinyl grooves.
Making a phono cartridge for extreme performance, EVERYTHING matters. It was built by a renown Swiss cartridge maker to our extreme specifications. The Hyper Sonic X4 is a unique moving coil cartridge with a Multi-Layer Core. Combined with a new, stronger magnetic alloy shaped for better focus of magnetic flux, less coil-turns could be used for a given electrical output. (only 0.2mV output with 4 ohm impedance)
A stiff sapphire cantilever was chosen. This is inserted into a hardened titanium sleeve to transfer every micro-deflection generated by the micro-ridge stylus to the moving coil. This gives the Sonic X4 the ability to trace every minute detail of the grooves cut in the lacquer by the sharp cutter of the lathe. The generator is rigidly held in place relative to the interface to the tonearm with a titanium superstructure. The body is made of shot-peen surface hardened titanium. Three tungsten inserts are strategically placed to enhance the inertia stability of the cartridge and improve resonance damping.
Playing a reference lacquer cut by Bernie Grundman, and comparing to the 30ips master that he used to cut that lacquer, this is as good as it gets.
16,220
13,683
2,665
Congratulations, Gary! It is clear that a lot of great thinking went into this cartridge!
Reactions: garylkoh
Nemal1
371
220
120
61
Any idea on price and availability. I’m in the market for a new cartridge and looking at alternatives to my usual Koetsu.
Peterhongkong
16
38
15
60
Hong Kong
I saw it today at the HK dealer Forthwise's showroom. Price HK$ 140.000,- or US$ 18.000,-
Congratulations Gary, it took you a long time since you mentioned it during our trip to Guangzhou 4 years ago but the result looks stunning :eek:)
Best regards, Peter
Reactions: garylkoh
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Best regards, Peter
Everything took longer than we thought.... But I am very pleased with the results. The combination of low impedance and low output means that it is unfortunately very demanding on the phonostage matching. Hence, we are considering a higher-output higher-impedance version for lower-gain/higher-noise phonostages.
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Thanks Gary. Would the new CH Precision P10 phono preamp be sufficient?
Perfect. The CH was one of the phonostages used during the development in Switzerland. Not sure if the designer owns a P1 or the P10 though.....
ChasFreeland
47
23
90
76
How would it pair with my Genesis phono pre-amp? Is it available in BKK?
Reactions: garylkoh
