Isolation for Lampi Pacific?
Sampajanna
661
775
170
Anyone try Revopods Under their Lampi? Other isolation suggestions?
bonzo75
22,650
13,684
2,710
London
Reactions: mtemur
Sampajanna
661
775
170
Thanks I will look into these. Did you take out teh Lampi feet and replace them or just put them alongside?
bonzo75
22,650
13,684
2,710
London
You can try initially alongside, but later will be good to take out Lampi feet So you have more room to adjust footer location.
At a lower price symposium balls are also nice. Avoid stillpoints and finite elemente
Golum
1,814
2,577
405
Lausanne, CH
bonzo75
22,650
13,684
2,710
London
Didn’t use them anyhow but can you elaborate on this one…
With shun mook the tone, flow, decay, space and size of the whole stage, all improves. With stillpoints it becomes a bit dry. Initially feels fast and tight but it is adding tops and drying out mids. I only tried up to the ultra 5s, not the ultra 6.
Effect might change a bit depending on platform underneath but never like stillpoints
Argonaut
2,425
1,655
530
N/A
If you are looking for neutrality with exceptional isolation then:
Image off the web.
Reactions: christoph
Sampajanna
661
775
170
Thanks for the advice!
