Jadis Monoblock Amplifiers
16,221
13,684
2,665
While it might be part of their sound
This is, definitely, an unavoidable question/concern.
there are some capacitors in Jadis I'd swap out in a hurry, and you would gain a bit of what was lost back.
Those big blue ones? They don't look super fancy. . .
4,704
(...) It's very obvious Jadis has less feedback based on measurements. While it might be part of their sound there are some capacitors in Jadis I'd swap out in a hurry, and you would gain a bit of what was lost back.
But than you would sacrifice the "Jadis sound" in the technology's table ...
There was a lot of debate on Jadis design choices, even in old WBF threads. IMO they are one of the most misunderstood brands.
Folsom
6,030
1,503
550
Eastern WA
The blue ones might be fine. They're not cheap cans. The issue is at some voltages there just aren't any options. IME seeking the highest C rating however isn't the clear winner for sound - it just isn't a factor that does or does not make good sound. It's more about some of the film caps. I'd have to study the circuit but I see some I consider overly bland.
Folsom
6,030
1,503
550
Eastern WA
Na. They don't use anything far enough from anything else that I'd call it signature defining.
Thieliste
815
296
360
53
Would you guys take JA120 over VAC Signature 200iq monos ?
gadawg58
220
215
150
NOT with your speakers, I would not ...I would not take VAC 200 either though, but for personal sonic preferences. If u go VAC 200, I d only go with the mono variant.
What do you not like about the VAC 200? Just curious as I know sonic preferences are very personal ... just curious as to what you are hearing that you don't like?
Thanks!
George
AudioLibertarian
234
114
150
NEW YORK CITY
Thanks!
George
I don't find KT-88, or its variants particularly "musical" to my preferences... Yes, these tubes in some designs have more power, and drive, and slam, and MIGHT drive some speakers with difficult loads (like Wilsons & Thiels) well, but to me most of that tube family lacks textural liquidity, and naturalness that I find in the the well designed amps using EL-34, or 845 tubes. I ve heard exceptions however, like the new Conrad Johnson line of amps , but that is also very system specific. Naturally the above is strictly my experience & preferences.
Thieliste
815
296
360
53
Well since i live 3 hours away from the Jadis factory why not try.
I will try to borrow a DA88S integrated just to hear how that sounds on my speakers vs SS class A.
If it's really good i could try monoblocks later on.
Reactions: Zappadaddy
Thieliste
815
296
360
53
Ok guys i'll be demoing a DA88S very soon on my Thiels, first tube amp i will try since i have the 3.7s
